lammps build error!
Dear lammps users,
i have problem while installing lammps after updating (for updating i used svn update, initially installed version LAMMPS (29 Jul 2011))
it is showing the following error could any one help me please.
[root@…436… src]$ make serial
make[1]: Entering directory /home/nav/mylammps/src/Obj_serial' g++ -O -DLAMMPS_GZIP -I../../lib/awpmd/ivutils/include -I../../lib/awpmd/systems/interact -I../../lib/atc -I../../lib/reax -I../../lib/poems -I../../lib/meam -I../STUBS -c force.cpp pppm_gpu_double.h:28: error: expected template-name before ‘<’ token pppm_gpu_double.h:28: error: expected {’ before ‘<’ token
pppm_gpu_double.h:28: error: expected unqualified-id before ‘<’ token
pppm_gpu_single.h:28: error: expected template-name before ‘<’ token
pppm_gpu_single.h:28: error: expected {' before ‘<’ token pppm_gpu_single.h:28: error: expected unqualified-id before ‘<’ token pppm_gpu_double.h: In member function ‘void LAMMPS_NS::Force::create_kspace(int, char**)’: pppm_gpu_double.h:16: error: invalid use of undefined type ‘class LAMMPS_NS::PPPMGPUDouble’ pppm_gpu_double.h:28: error: forward declaration of ‘class LAMMPS_NS::PPPMGPUDouble’ pppm_gpu_single.h:16: error: invalid use of undefined type ‘class LAMMPS_NS::PPPMGPUSingle’ pppm_gpu_single.h:28: error: forward declaration of ‘class LAMMPS_NS::PPPMGPUSingle’ make[1]: *** [force.o] Error 1 make[1]: Leaving directory /home/nav/mylammps/src/Obj_serial’
make: *** [serial] Error 2
thanking you
with regards
Naveen
You might try a “make no-all” then make yes for the packages you really want. It looks like you’re getting the GPU package, which you might not really want.
See: http://lammps.sandia.gov/doc/Section_start.html#start_3
Paul
