Hi Steve,
I just want to ask you that how can I plot the variation in distribution frequency of interatomic bond length using LAMMPS (a sample image is attached).
Regards,
Saurav Goel
Hi Steve,
Regards,
Saurav Goel
You can use the compute bond/local to get
bond lengths. You can feed that info
to fix ave/histo to tally a histogram. You can
output that to a file and plot it.
Hi Steve,
Thanks for info. What should one do with atom_style atomic to make use of this command.
Regards,
Saurav
Hi Steve,
this command.
if you don't have explicit bonds, you probably are better off
computing a radial distribution function, g(r) in any case.
If you don't have bonds, you can't use compute bond/local.
You said you wanted to compute the distribution of bond
lengths, so I assumed you had bonds. The rdf is probably
best, see the compute rdf or compute pair/local commands.
You can also look at compute coord/atom.
