Dear List,
I get a segmentation fault running the examples/USER/misc/srp/in.srp script using the most recent LAMMPS version from 9/1 2017. Both code and script without modifications. It runs for the stable_17Nov2016 version. The error is:
Removed/inserted 0/2700 bond particles. (../fix_srp.cpp:249)
Extending ghost comm cutoff. New 3.523044, old 3.000000. (../fix_srp.cpp:271)
[HP-EliteBook-820-G1:03171] *** Process received signal ***
[HP-EliteBook-820-G1:03171] Signal: Segmentation fault (11)
[HP-EliteBook-820-G1:03171] Signal code: Address not mapped (1)
[HP-EliteBook-820-G1:03171] Failing at address: (nil)
[HP-EliteBook-820-G1:03171] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390)[0x7f4d3c8eb390]
[HP-EliteBook-820-G1:03171] [ 1] lmp_zqex_vanilla(_ZN9LAMMPS_NS18NPairHalfBinNewton5buildEPNS_9NeighListE+0x2be)[0xaea86e]
[HP-EliteBook-820-G1:03171] [ 2] lmp_zqex_vanilla(_ZN9LAMMPS_NS8Neighbor5buildEi+0x315)[0x706e75]
[HP-EliteBook-820-G1:03171] [ 3] lmp_zqex_vanilla(_ZN9LAMMPS_NS6FixSRP15setup_pre_forceEi+0x7b2)[0x910df2]
[HP-EliteBook-820-G1:03171] [ 4] lmp_zqex_vanilla(_ZN9LAMMPS_NS6Modify15setup_pre_forceEi+0xe7)[0xaac487]
[HP-EliteBook-820-G1:03171] [ 5] lmp_zqex_vanilla(_ZN9LAMMPS_NS6Verlet5setupEv+0x244)[0xb89a64]
[HP-EliteBook-820-G1:03171] [ 6] lmp_zqex_vanilla(_ZN9LAMMPS_NS3Run7commandEiPPc+0x335)[0x5babb5]
[HP-EliteBook-820-G1:03171] [ 7] lmp_zqex_vanilla(_ZN9LAMMPS_NS5Input15command_creatorINS_3RunEEEvPNS_6LAMMPSEiPPc+0x39)[0xace1d9]
[HP-EliteBook-820-G1:03171] [ 8] lmp_zqex_vanilla(_ZN9LAMMPS_NS5Input15execute_commandEv+0x813)[0xacba23]
[HP-EliteBook-820-G1:03171] [ 9] lmp_zqex_vanilla(_ZN9LAMMPS_NS5Input4fileEv+0x546)[0xacc716]
[HP-EliteBook-820-G1:03171] [10] lmp_zqex_vanilla(main+0x46)[0x4cced6]
[HP-EliteBook-820-G1:03171] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f4d3b585830]
[HP-EliteBook-820-G1:03171] [12] lmp_zqex_vanilla(_start+0x29)[0x4ce959]
[HP-EliteBook-820-G1:03171] *** End of error message ***
Segmentation fault (core dumped)
valgrind:
==29109== Invalid read of size 4
==29109== at 0xB10115: LAMMPS_NS::NPairHalfBinNewton::build(LAMMPS_NS::NeighList*) (npair_half_bin_newton.cpp:85)
==29109== by 0x754C05: LAMMPS_NS::Neighbor::build(int) (neighbor.cpp:1761)
==29109== by 0x94BD31: LAMMPS_NS::FixSRP::setup_pre_force(int) (fix_srp.cpp:303)
