LAMMPS_CUDA Precision
I installed the August 25, 2011 version of LAMMPS (all packages) on our cluster. When I run LAMMPS however, I get these warnings about the
difference in precision of the cuda vs. cpp code.
LAMMPS (25 Aug 2011)
Using LAMMPS_CUDA
CUDA WARNING: Compile Settings of cuda and cpp code differ!
CUDA WARNING: Global Precision: cuda 0 cpp 2
CUDA WARNING: X Precision: cuda 0 cpp 2
I have set the precision to double when I built the libraries in the Makefiles under user-cuda and gpu. Not sure what “0” precision means. Is there a setting
within the LAMMPS /src directory that I might have overlooked?
Akila
Hi
in principal this should not happen (this is a really helpfull answer isnt it?). What you can do is go to lib/cuda and do a "make clean" followed by "make -j 8".
Then go to the src directory and delete the files in "Obj_MACHINENAME" and compile again with "make MACHINENAME -j 8".
Let me know if that works.
Cheers
Christian
-------- Original-Nachricht --------
Hello Christian,
Thanks, that did the trick I believe! I also included the CUDA PRECISION and CUDA FFT flags in the Makefile under the src directory as I was getting
the following error message with one of the examples (in.phosphate.gpu under examples/cuda directory):
ERROR: Using kspace_style pppm/cuda without cufft is not possible. Compile with cufft=1 to include cufft
I no longer get this error but for the example, “in.phosphate.gpu” under the examples/gpu directory, I get
ERROR: Invalid kspace style
Should this really be:
kspace_style pppm/gpu 1e-5
and NOT
kspace_style pppm/gpu/ 1e-5
in the input file as using the former does not return an error.
Akila
Hello Christian,
I no longer get this error but for the example, "in.phosphate.gpu" under the
no. you cannot mix the GPU package and the USER-CUDA package.
Axel,
I think I might have confused you. Sorry.
I was using the in.phosphate.cuda under /examples/USER/cuda
which seems to be working fine.
However, in.phosphate.gpu under /examples/gpu is the one that gives me the error: Invalid kspace style.
It appears as the following in the input file:
kspace_style pppm/gpu/<precision> 1e-5
I did run lammps with -cuda off to use the gpu package and disable the USER-CUDA package.
Akila
Axel,
that has to be pppm/gpu 1.e-5
whether you use single or double precision
in pppm/gpu is now determined by the
precision you choose for the FFT library.
i guess the example has not been updated
since the single precision FFT code was
folded into the distribution.
Axel,
That's what I thought as I had mentioned in my first email, removing the precision made it work.
Thanks!
Akila
