LAMMPS errors - Segmentation fault and address not mapped
I was executing a very simple script on LAMMPS on my university’s supercomputer cluster to learn how to use the software. Unfortunately, every time I run the script, I receive the following error:
LAMMPS (10 Oct 2012)
Scanning data file …
1 = max bonds/atom
1 = max angles/atom
Reading data file …
orthogonal box = (0 0 -0.5) to (10 10 0.5)
3 atoms
3 bonds
[node013:15005] *** Process received signal ***
[node013:15005] Signal: Segmentation fault (11)
[node013:15005] Signal code: Address not mapped (1)
[node013:15005] Failing at address: (nil)
[node013:15005] [ 0] /lib64/libpthread.so.0 [0x2aaaab1a6be0]
[node013:15005] [ 1] /home/auxetic/LAMMPS/lammps-10Oct12/src/lmp_albert [0x41c9ad]
[node013:15005] [ 2] /home/auxetic/LAMMPS/lammps-10Oct12/src/lmp_albert [0x706bab]
[node013:15005] [ 3] /home/auxetic/LAMMPS/lammps-10Oct12/src/lmp_albert [0x7083ab]
[node013:15005] [ 4] /home/auxetic/LAMMPS/lammps-10Oct12/src/lmp_albert [0x56c4f2]
[node013:15005] [ 5] /home/auxetic/LAMMPS/lammps-10Oct12/src/lmp_albert [0x56cb2e]
[node013:15005] [ 6] /home/auxetic/LAMMPS/lammps-10Oct12/src/lmp_albert [0x57a1b6]
[node013:15005] [ 7] /lib64/libc.so.6(__libc_start_main+0xf4) [0x2aaaab8e0994]
[node013:15005] [ 8] /home/auxetic/LAMMPS/lammps-10Oct12/src/lmp_albert(_ZNSt8ios_base4InitD1Ev+0x39) [0x40a6c9]
[node013:15005] *** End of error message ***
I was executing a very simple script on LAMMPS on my university's
Scanning data file ...
  1 = max bonds/atom
  1 = max angles/atom
Reading data file ...
  3 atoms
  3 bonds
[0x41c9ad]
[0x706bab]
[0x7083ab]
[0x56c4f2]
[0x56cb2e]
[0x57a1b6]
[0x2aaaab8e0994]
[0x40a6c9]
mpirun noticed that process rank 0 with PID 15005 on node node013 exited on
signal 11 (Segmentation fault).
together with a core file containing symbols within which I have no idea
it works for me, but i have not yet fully caught up with the latest code:
[[email protected]... tmp]$ mpirun -np 4 ../src/lmp_openmpi < in.test
LAMMPS (19 Sep 2012-ICMS)
  1 = max bonds/atom
  1 = max angles/atom
  2 by 2 by 1 MPI processor grid
  3 atoms
  3 bonds
  2 angles
  2 = max # of 1-2 neighbors
  2 = max # of 1-3 neighbors
  4 = max # of 1-4 neighbors
  2 = max # of special neighbors
what it is. Also, interestingly enough, the log.lammps remains empty after
running the script.
that is to be expected. that file is block buffered.
I have included the contents of my input and data files below. Could someone
explain to me what I am doing wrong please?
apparently not. either there has been a change
that would require a change in the data/input, or
you have a miscompiled executable, or there has
been a bug introduced during the last month.
works for me with the current LAMMPS version.
Thank you all for your help. Probably lammps is not installed correctly on the cluster. I will be trying to run it on other computers. Thanks once again for your help and sorry if I have bothered you with my query.
Regards,
Joseph
