I am trying to install lammps on CentOs V6.2
I have openmpi-1.5.3-3.el6.x86_64 package installed in /usr/lib64/openmpi and the binaries are in /usr/lib64/openmpi/bin.
I have unistalled user-cuda, kim and enabled kspace, class2, gpu. I have installed gpu libraries in the lammps/lib/gpu as instructed in the doc and everything went fine. Then I ran ./nvc_get_devices and got the details of my system. Everything went fine. However, When I modify the Makefile.openmpi (I modified the Makefile.openmpi supplied by default in lammps/src/MAKE to include my FFT libraries) given below, and hit ‘make openmpi’ from within src, installation errors out.
The error message is:
pstub -limf -lstdc++ -o ../lmp_openmpi
/usr/bin/ld: cannot find -lcolvars
collect2: ld returned 1 exit status
make[1]: *** [../lmp_openmpi] Error 1
make[1]: Leaving directory `/nfsgen/souvikp/lammps-6Jun12/src/Obj_openmpi'
make: *** [openmpi] Error 2
Could anyone please tell me what am I doing wrong?
you installed the USER-COLVARS package, but apparently
didn't compile the colvars library in lib/colvars.
please have another (closer) look at the LAMMPS installation
instructions and explanations for packages using
extra libraries in lib
p.s.: you will make your life easier wrt. GPU computing,
if you configure only one of the two GPU acceleration
packages at a time.
