LAMMPS Hanging on read_molecule command
Hi everyone,
I am attempting to simulate a simple CO2 molecule. However, LAMMPS is hanging when trying to read my molecule file sometimes. Specifically, when running the ‘in.co2’ script that I have copied at the end of this message, there are 3 possible outcomes.
  1. The script hangs after outputting:
LAMMPS (10 Feb 2015)
Created orthogonal box = (0 0 0) to (10 10 10)
Read molecule 1:
3 atoms with 2 types
2 bonds with 1 types
1 angles with 1 types
0 dihedrals with 0 types
0 impropers with 0 types
At this point, the script hangs, and must be killed.
  1. The script executes, and outputs the following (sample of only the first thermo output, the script completes with the same thermo output and no errors):
Read molecule 1:
Created 3 atoms
Finding SHAKE clusters …
0 = # of size 2 clusters
0 = # of size 3 clusters
0 = # of size 4 clusters
1 = # of frozen angles
Neighbor list info …
1 neighbor list requests
update every 1 steps, delay 0 steps, check yes
master list distance cutoff = 2.8
Setting up run …
SHAKE stats (type/ave/delta) on step 0
1 0.322222 0 6
1 180 0
Memory usage per processor = 6.86293 Mbytes
Step Temp TotEng PotEng
0 0 0 0
SHAKE stats (type/ave/delta) on step 1000
1 0.322222 0 6
1 180 0
1000 0 0 0
SHAKE stats (type/ave/delta) on step 100000
1 0.322222 0 6
1 180 0
100000 0 0 0
Loop time of 0.101181 on 1 procs for 100000 steps with 3 atoms
Pair time () = 0.00734854 (7.26278) Bond time () = 0.00727963 (7.19468)
Neigh time () = 0 (0) Comm time () = 0.0124381 (12.2929)
Outpt time () = 0.000585556 (0.578723) Other time () = 0.073529 (72.6709)
Nlocal: 3 ave 3 max 3 mi
Histogram: 1 0 0 0 0 0 0 0 0 0
Nghost: 0 ave 0 max 0 min
Neighs: 0 ave 0 max 0 min
Total # of neighbors = 0
Ave neighs/atom = 0
Ave special neighs/atom = 2
Neighbor list builds = 0
Dangerous builds = 0
  1. The script runs and finishes, but the shake seems to fail early on:
Read molecule 1:
Created 3 atoms
Setting up run …
1 1.17401 1.70357 6
1 99.1523 0
0 0 0 0
1 nan nan 6
1 nan nan
100000 nan nan 0
Loop time of 0.093082 on 1 procs for 100000 steps with 3 atoms
Pair time () = 0.00688314 (7.39471) Bond time () = 0.00655746 (7.04483)
Neigh time () = 0 (0) Comm time () = 0.0131786 (14.158)
Outpt time () = 0.000461817 (0.49614) Other time () = 0.0660009 (70.9063)
Nlocal: 3 ave 3 max 3 min
Ave neighs/atom = 0
Hi everyone,
running the 'in.co2' script that I have copied at the end of this message,
Read molecule 1:
this could happen, if your molecule file doesn't have an end of line
character at the end. it could also be a bug in the molecule file
reader code (i vaguely remember sending in a fix for something like
that) that has been corrected since. please try again with the latest
(stable) LAMMPS version.
2. The script executes, and outputs the following (sample of only the first
errors):
Read molecule 1:
Created 3 atoms
Finding SHAKE clusters ...
Neighbor list info ...
Setting up run ...
  1 0.322222 0 6
  1 180 0
whoa there. you cannot use SHAKE on linear molecules. the solution for
the 180 degree angle is degenerate. you need to use on of the rigid
fixes.
The bigger problem is this:
Coords
1 0
2 0.32222222222 # 116pm / 3.6angstroms
3 0.64444444444
You need 3 values per atom, else the code
is storing garbage. There should be
an error check for this mis-formatting.
Thanks, this is very helpful info! It might be helpful if the documentation mentioned that ‘fix shake’ should not be used on linear molecules, not sure if that’s something everyone can be expected to know (I’m definitely not an expert, tho, maybe everyone else does know that ;)).
Aaron
Good point - I thought it was documented, but don’t see it.
I added it to the Restrictions section for fix shake.
