Lammps installation CentOS cluster
Good day lammps-users,
Please help me installing lammps on a CentOS computing cluster. I followed the steps on this link (http://lammps.sandia.gov/threads/msg12768.html) but after performing “make linux” or “make mpi”, it sends some error (fftw3). Does anyone here can suggest a direct procedure in installing. I’ll appreciate it very much. Thank you.
after performing "make linux" or "make mpi", it sends some error (fftw3).
Does anyone here can suggest a direct procedure in installing. I'll
a detailed description of how to install LAMMPS is given in the
manual. which is likely much more reliable than an 8 year old e-mail.
axell
You need to install FFTW3 if CentOS does not come with it by default. If it does, make sure the paths for it in the Makefile are set up properly.
