lammps installation
Hi all
When I want to install 20Apr11 or 1Apr11 LAMMPS, I recieve the following error when I write “make g++” in src folder in Terminal or “make openmpi” …
g++4 -g -O -DLAMMPS_GZIP -DMPICH_SKIP_MPICXX -DFFT_FFTW -M write_restart.cpp > write_restart.d
/bin/sh: g++4: not found
make[1]: *** [write_restart.d] Error 127
make[1]: Leaving directory `/home/saly/Desktop/LAMMPS/lammps-1Apr11/src/Obj_g++’
make: *** [g++] Error 2
saly@…2593…:~/Desktop/LAMMPS/lammps-1Apr11/src$
Would you please help me?
Thanks alot
Regards
Saly
You can open “…/src/MAKE/Makefile.g++” with a text editor, and replace all “g++4” with “g++”. The problem will work out.
Regards,
Mehdi
Hi Mehdi
I do it but I receive the following error:
Makefile:102: pair_born_coul_long.d: No such file or directory
Makefile:102: pair_born.d: No such file or directory
Makefile:102: pair_buck_coul_cut.d: No such file or directory
Makefile:102: pair_buck_coul_long.d: No such file or directory
Makefile:102: pair_buck.d: No such file or directory
Makefile:102: pair_comb.d: No such file or directory
Makefile:102: pair_coul_cut.d: No such file or directory
Makefile:102: pair_coul_debye.d: No such file or directory
Makefile:102: pair_coul_long.d: No such file or directory
Makefile:102: pair.d: No such file or directory
Makefile:102: pair_dpd.d: No such file or directory
Makefile:102: pair_dpd_tstat.d: No such file or directory
Makefile:102: pair_eam_alloy.d: No such file or directory
Makefile:102: pair_eam.d: No such file or directory
Makefile:102: pair_eam_fs.d: No such file or directory
Makefile:102: pair_eim.d: No such file or directory
Makefile:102: pair_gauss.d: No such file or directory
Makefile:102: pair_hbond_dreiding_lj.d: No such file or directory
Makefile:102: pair_hbond_dreiding_morse.d: No such file or directory
Makefile:102: pair_hybrid.d: No such file or directory
Makefile:102: pair_hybrid_overlay.d: No such file or directory
Makefile:102: pair_lj96_cut.d: No such file or directory
Makefile:102: pair_lj_charmm_coul_charmm.d: No such file or directory
Makefile:102: pair_lj_charmm_coul_charmm_implicit.d: No such file or directory
Makefile:102: pair_lj_charmm_coul_long.d: No such file or directory
Makefile:102: pair_lj_cut_coul_cut.d: No such file or directory
Makefile:102: pair_lj_cut_coul_debye.d: No such file or directory
Makefile:102: pair_lj_cut_coul_long.d: No such file or directory
Makefile:102: pair_lj_cut_coul_long_tip4p.d: No such file or directory
Makefile:102: pair_lj_cut.d: No such file or directory
Makefile:102: pair_lj_expand.d: No such file or directory
Makefile:102: pair_lj_gromacs_coul_gromacs.d: No such file or directory
Makefile:102: pair_lj_gromacs.d: No such file or directory
Makefile:102: pair_lj_smooth.d: No such file or directory
Makefile:102: pair_morse.d: No such file or directory
Makefile:102: pair_soft.d: No such file or directory
Makefile:102: pair_sw.d: No such file or directory
Makefile:102: pair_table.d: No such file or directory
Makefile:102: pair_tersoff.d: No such file or directory
Makefile:102: pair_tersoff_zbl.d: No such file or directory
Makefile:102: pair_yukawa.d: No such file or directory
Makefile:102: pppm.d: No such file or directory
Makefile:102: pppm_tip4p.d: No such file or directory
Makefile:102: random_mars.d: No such file or directory
Makefile:102: random_park.d: No such file or directory
Makefile:102: read_data.d: No such file or directory
Makefile:102: read_restart.d: No such file or directory
Makefile:102: region_block.d: No such file or directory
Makefile:102: region_cone.d: No such file or directory
Makefile:102: region.d: No such file or directory
Makefile:102: region_cylinder.d: No such file or directory
Makefile:102: region_intersect.d: No such file or directory
Makefile:102: region_plane.d: No such file or directory
Makefile:102: region_prism.d: No such file or directory
Makefile:102: region_sphere.d: No such file or directory
Makefile:102: region_union.d: No such file or directory
Makefile:102: remap.d: No such file or directory
Makefile:102: remap_wrap.d: No such file or directory
Makefile:102: replicate.d: No such file or directory
Makefile:102: respa.d: No such file or directory
Makefile:102: run.d: No such file or directory
Makefile:102: set.d: No such file or directory
Makefile:102: special.d: No such file or directory
Makefile:102: thermo.d: No such file or directory
Makefile:102: timer.d: No such file or directory
Makefile:102: universe.d: No such file or directory
Makefile:102: update.d: No such file or directory
Makefile:102: variable.d: No such file or directory
Makefile:102: velocity.d: No such file or directory
Makefile:102: verlet.d: No such file or directory
Makefile:102: write_restart.d: No such file or directory
g++ -g -O -DLAMMPS_GZIP -DMPICH_SKIP_MPICXX -DFFT_FFTW -M write_restart.cpp > write_restart.d
write_restart.cpp:15: fatal error: mpi.h: No such file or directory
compilation terminated.
make[1]: Leaving directory `/home/nahid/Desktop/LAMMPS/lammps-20Apr11/src/Obj_g++’
Thanks alot for your time and attention
Regards
Saly
what version of MPI have been installed on your machine? It belongs to your installed MPI libbrary. Have you installed openmpi? Do you have Ubuntu?
Regards,
Mehdi
Hi
Yes I have Ubuntu. Do you mean that I have to install openmpi from synaptic manager?
Regards
Saly
Exactly!
