lammps minimization error
Dear users,
I tried to build and LAMMPS dynamic properties of the “F-substituted p3ht” polymer using "polymatic"
But i get an error " LAMMPS energy minimization did not complete properly"
setting section created by “moltamplate” using GAFF force field parameters.
The input files are given below
1) p3ht.lt (Inpute file for “moltemplate”)
import “gaff.lt
# From “gaff.lt”:
# @atom:cc1 # Sp2 carbons in non-pure aromatic systems
# @atom:cc4 # Sp2 carbons in non-pure aromatic systems
# @atom:cd # Sp2 carbons in non-pure aromatic systems, identical to cc
# @atom:hc # H bonded to aliphatic carbon without electrwd. group
# @atom:ss # Sp3 S in thio-ester and thio-ether
# @atom:f # Fluorine
# @atom:c3 # Sp3 C(c3)
f-p3ht inherits GAFF {
# atomID molID atomType charge X Y Z
write(“Data Atoms”) {
$atom:C1 $mol @atom:cc1 -0.251330 -2.992197 -0.970903 0.136447
$atom:C2 $mol @atom:cd 0.285577 -1.615590 -0.967778 0.177626
$atom:C3 $mol @atom:cd 0.072106 -1.087636 0.351460 -0.000810
$atom:C4 $mol @atom:cc4 -0.233082 -2.091681 1.279310 -0.167091
$atom:S5 $mol @atom:ss 0.358712 -3.603153 0.566381 -0.107759
$atom:C6 $mol @atom:c3 -0.227398 0.420925 0.661048 -0.001617
$atom:C7 $mol @atom:c3 -0.182741 0.966860 0.621737 1.402630
$atom:H8 $mol @atom:hc 0.106497 0.573831 1.670184 -0.455183
$atom:H9 $mol @atom:hc 0.118755 0.935600 -0.092766 -0.645282
$atom:C10 $mol @atom:c3 -0.174215 2.443562 0.921000 1.437669
$atom:H11 $mol @atom:hc 0.101399 0.418809 1.367108 2.038043
$atom:H12 $mol @atom:hc 0.109635 0.779590 -0.391022 1.848640
$atom:H13 $mol @atom:hc 0.091229 3.010968 0.173859 0.831591
$atom:H14 $mol @atom:hc 0.090014 2.649173 1.936898 1.021521
$atom:C15 $mol @atom:c3 -0.167890 2.967827 0.872695 2.884878
$atom:C16 $mol @atom:c3 -0.174529 4.444995 1.169801 2.919563
$atom:H17 $mol @atom:hc 0.091411 2.760749 -0.142680 3.301520
$atom:H18 $mol @atom:hc 0.089724 2.401503 1.620895 3.490604
$atom:C19 $mol @atom:c3 -0.317959 4.991043 1.130469 4.323742
$atom:H20 $mol @atom:hc 0.092143 4.991724 0.423248 2.284398
$atom:H21 $mol @atom:hc 0.091541 4.633626 2.182023 2.472908
$atom:H22 $mol @atom:hc 0.100285 6.085170 1.353308 4.322982
$atom:H23 $mol @atom:hc 0.102390 4.477507 1.885499 4.966947
$atom:H24 $mol @atom:hc 0.102972 4.836601 0.121813 4.777905
$atom:F25 $mol @atom:f -0.275247 -0.837002 -2.055267 0.361113
write(“Data Bond List”) {
$bond:C1C2 $atom:C1 $atom:C2
$bond:C2C3 $atom:C2 $atom:C3
$bond:C3C4 $atom:C3 $atom:C4
$bond:C4S5 $atom:C4 $atom:S5
$bond:C1S5 $atom:C1 $atom:S5
$bond:C2F25 $atom:C2 $atom:F25
$bond:C3C6 $atom:C3 $atom:C6
$bond:C6C7 $atom:C6 $atom:C7
$bond:C7C10 $atom:C7 $atom:C10
$bond:C10C15 $atom:C10 $atom:C15
$bond:C15C16 $atom:C15 $atom:C16
$bond:C16C19 $atom:C16 $atom:C19
$bond:C6H8 $atom:C6 $atom:H8
$bond:C6H9 $atom:C6 $atom:H9
$bond:C7H11 $atom:C7 $atom:H11
$bond:C7H12 $atom:C7 $atom:H12
$bond:C10H13 $atom:C10 $atom:H13
$bond:C10H14 $atom:C10 $atom:H14
$bond:C15H18 $atom:C15 $atom:H18
$bond:C15H17 $atom:C15 $atom:H17
$bond:C16H20 $atom:C16 $atom:H20
$bond:C16H21 $atom:C16 $atom:H21
$bond:C19H23 $atom:C19 $atom:H23
$bond:C19H24 $atom:C19 $atom:H24
$bond:C19H22 $atom:C19 atom:H22<br>}<br><br><br><br>} # F-p3ht<br><br><br><br>**2 ) min.lmps**<br><br>#------------init section------------------<br>units real<br>atom_style full<br>bond_style hybrid harmonic<br>angle_style hybrid harmonic<br>dihedral_style hybrid fourier<br>improper_style hybrid cvff<br>pair_style hybrid lj/charmm/coul/long 9.0 10.0 10.0<br>kspace_style pppm 0.0001<br>pair_modify mix arithmetic<br>special_bonds amber<br><br># Data file input<br>read_data data.lmps (= pack.lmps by polymatic)<br><br><br><br>#-------------------setting section---------------<br>pair_coeff 1 1 lj/charmm/coul/long 0.0860 3.39966950842 # OPLS<br>pair_coeff 2 2 lj/charmm/coul/long 0.0860 3.39966950842 # OPLS<br>pair_coeff 3 3 lj/charmm/coul/long 0.0860 3.39966950842 # OPLS<br>pair_coeff 4 4 lj/charmm/coul/long 0.0860 3.39966950842 # OPLS<br>pair_coeff 5 5 lj/charmm/coul/long 0.0860 3.39966950842 # OPLS<br>pair_coeff 6 6 lj/charmm/coul/long 0.0157 2.64953278775 # OPLS<br>pair_coeff 7 7 lj/charmm/coul/long 0.2500 3.56359487256 # W. Cornell CH3SH and CH3SCH3 FEP's<br>pair_coeff 9 9 lj/charmm/coul/long 0.1094 3.39966950842 # OPLS<br>pair_coeff 8 8 lj/charmm/coul/long 0.061 3.11814551349 # Gough et al. JCC 13,(1992),963.<br>bond_coeff 1 harmonic 303.1 1.5350 # SOURCE1 14664 0.0048<br>bond_coeff 2 harmonic 337.3 1.0920 # SOURCE3 2815 0.0059<br>bond_coeff 3 harmonic 337.3 1.4990 # SOURCE3 50 0.0096<br>bond_coeff 4 harmonic 418.3 1.4290 # SOURCE1 740 0.0069<br>bond_coeff 5 harmonic 504.0 1.3710 # SOURCE3 523 0.0217<br>bond_coeff 6 harmonic 504.0 1.3710 # SOURCE3 523 0.0217<br>bond_coeff 7 harmonic 504.0 1.3710 # SOURCE3 523 0.0217<br>bond_coeff 8 harmonic 504.0 1.3710 # SOURCE3 523 0.0217<br>bond_coeff 9 harmonic 279.3 1.7370 # SOURCE3 52 0.0194<br>bond_coeff 10 harmonic 279.3 1.7370 # SOURCE3 52 0.0194<br>bond_coeff 11 harmonic 279.3 1.7370 # SOURCE3 52 0.0194<br>bond_coeff 12 harmonic 279.3 1.7370 # SOURCE3 52 0.0194<br>bond_coeff 13 harmonic 418.3 1.4290 # SOURCE1 740 0.0069<br>bond_coeff 14 harmonic 368.6 1.3401 # NEW 24<br>angle_coeff 1 harmonic 63.21 110.63 # SOURCE3 507 2.7845<br>angle_coeff 2 harmonic 46.37 110.05 # SOURCE3 2092 0.6991<br>angle_coeff 3 harmonic 39.43 108.35 # SOURCE3 2380 0.9006<br>angle_coeff 4 harmonic 63.58 111.89 # CORR 700<br>angle_coeff 5 harmonic 47.20 110.86 # SOURCE3 85 1.0276<br>angle_coeff 6 harmonic 68.16 114.19 # SOURCE3 517 6.5960<br>angle_coeff 7 harmonic 62.45 120.12 # CORR 31<br>angle_coeff 8 harmonic 65.44 111.55 # CORR 884<br>angle_coeff 9 harmonic 65.44 111.55 # CORR 884<br>angle_coeff 10 harmonic 65.44 111.55 # CORR 884<br>angle_coeff 11 harmonic 65.44 111.55 # CORR 884<br>angle_coeff 12 harmonic 64.81 119.45 # SOURCE3 35 8.2040<br>angle_coeff 13 harmonic 64.81 119.45 # SOURCE3 35 8.2040<br>angle_coeff 14 harmonic 64.66 115.97 # SOURCE3 4 3.0507<br>angle_coeff 15 harmonic 68.16 114.19 # SOURCE3 517 6.5960<br>angle_coeff 16 harmonic 68.16 114.19 # SOURCE3 517 6.5960<br>angle_coeff 17 harmonic 68.16 114.19 # SOURCE3 517 6.5960<br>angle_coeff 18 harmonic 68.16 114.19 # SOURCE3 517 6.5960<br>angle_coeff 19 harmonic 67.01 89.91 # SOURCE3 11 2.2164<br>angle_coeff 20 harmonic 67.01 89.91 # SOURCE3 11 2.2164<br>angle_coeff 21 harmonic 66.35 119.41 # NEW 7<br>angle_coeff 22 harmonic 67.42 121.08 # NEW 28<br>angle_coeff 23 harmonic 67.42 121.08 # NEW 28<br>dihedral_coeff 1 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 2 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 3 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 4 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 5 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 6 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 7 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 8 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 9 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 10 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 11 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 12 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 13 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 14 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 15 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 16 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 17 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 18 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 19 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 20 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 21 fourier 1 4.0 2 180.0 # statistic value of parm94<br>dihedral_coeff 22 fourier 1 0.155555555556 3 0.0 # JCC,7,(1986),230<br>dihedral_coeff 23 fourier 1 0.155555555556 3 0.0 # JCC,7,(1986),230<br>dihedral_coeff 24 fourier 1 0.0 3 0.0 # same as X-c3-ca-X<br>dihedral_coeff 25 fourier 1 0.0 3 0.0 # same as X-c3-ca-X<br>dihedral_coeff 26 fourier 1 0.0 3 0.0 # same as X-c3-ca-X<br>dihedral_coeff 27 fourier 1 0.0 3 0.0 # same as X-c3-ca-X<br>dihedral_coeff 28 fourier 1 0.0 3 0.0 # same as X-c3-ca-X<br>dihedral_coeff 29 fourier 1 0.0 3 0.0 # same as X-c3-ca-X<br>dihedral_coeff 30 fourier 1 0.15 3 0.0 # Junmei et al, 1999<br>dihedral_coeff 31 fourier 1 0.16 3 0.0 # Junmei et al, 1999<br>dihedral_coeff 32 fourier 3 0.18 3 0.0 0.25 2 180.0 0.2 1 180.0 # Junmei et al, 1999<br><br><br><br># Minimization Step<br>min_style cg<br>minimize 1e-25 1e-25 500000 1000000<br><br><br><br># Data file output<br>write_data min.lmps<br><br><br><br>**OUTPUTE FILES**<br><br><br><br>1) **log.lmps as follows**<br><br><br><br>LAMMPS (7 Dec 2015)<br>WARNING: OMP_NUM_THREADS environment is not set. (../comm.cpp:90)<br>using 1 OpenMP thread(s) per MPI task<br>package omp 0<br>using multi-threaded neighbor list subroutines<br>package omp 1<br>using multi-threaded neighbor list subroutines<br>#------------init section------------------<br>units real<br>atom_style full<br>bond_style hybrid harmonic<br>angle_style hybrid harmonic<br>dihedral_style hybrid fourier<br>improper_style hybrid cvff<br>pair_style hybrid lj/charmm/coul/long 9.0 10.0 10.0<br>kspace_style pppm 0.0001<br>pair_modify mix arithmetic<br>special_bonds amber<br><br><br><br># Data file input<br>read_data data.lmps<br>orthogonal box = (0 0 0) to (20 20 20)<br>2 by 2 by 4 MPI processor grid<br>reading atoms ...<br>75 atoms<br>scanning bonds ...<br>3 = max bonds/atom<br>scanning angles ...<br>6 = max angles/atom<br>scanning dihedrals ...<br>9 = max dihedrals/atom<br>reading bonds ...<br>75 bonds<br>reading angles ...<br>135 angles<br>reading dihedrals ...<br>177 dihedrals<br>4 = max # of 1-2 neighbors<br>6 = max # of 1-3 neighbors<br>12 = max # of 1-4 neighbors<br>16 = max # of special neighbors<br>#-------------------setting section---------------<br>pair_coeff 1 1 lj/charmm/coul/long 0.0860 3.39966950842 # OPLS<br>pair_coeff 2 2 lj/charmm/coul/long 0.0860 3.39966950842 # OPLS<br>pair_coeff 3 3 lj/charmm/coul/long 0.0860 3.39966950842 # OPLS<br>pair_coeff 4 4 lj/charmm/coul/long 0.0860 3.39966950842 # OPLS<br>pair_coeff 5 5 lj/charmm/coul/long 0.0860 3.39966950842 # OPLS<br>pair_coeff 6 6 lj/charmm/coul/long 0.0157 2.64953278775 # OPLS<br>pair_coeff 7 7 lj/charmm/coul/long 0.2500 3.56359487256 # W. Cornell CH3SH and CH3SCH3 FEP's<br>pair_coeff 9 9 lj/charmm/coul/long 0.1094 3.39966950842 # OPLS<br>pair_coeff 8 8 lj/charmm/coul/long 0.061 3.11814551349 # Gough et al. JCC 13,(1992),963.<br>bond_coeff 1 harmonic 303.1 1.5350 # SOURCE1 14664 0.0048<br>bond_coeff 2 harmonic 337.3 1.0920 # SOURCE3 2815 0.0059<br>bond_coeff 3 harmonic 337.3 1.4990 # SOURCE3 50 0.0096<br>bond_coeff 4 harmonic 418.3 1.4290 # SOURCE1 740 0.0069<br>bond_coeff 5 harmonic 504.0 1.3710 # SOURCE3 523 0.0217<br>bond_coeff 6 harmonic 504.0 1.3710 # SOURCE3 523 0.0217<br>bond_coeff 7 harmonic 504.0 1.3710 # SOURCE3 523 0.0217<br>bond_coeff 8 harmonic 504.0 1.3710 # SOURCE3 523 0.0217<br>bond_coeff 9 harmonic 279.3 1.7370 # SOURCE3 52 0.0194<br>bond_coeff 10 harmonic 279.3 1.7370 # SOURCE3 52 0.0194<br>bond_coeff 11 harmonic 279.3 1.7370 # SOURCE3 52 0.0194<br>bond_coeff 12 harmonic 279.3 1.7370 # SOURCE3 52 0.0194<br>bond_coeff 13 harmonic 418.3 1.4290 # SOURCE1 740 0.0069<br>bond_coeff 14 harmonic 368.6 1.3401 # NEW 24<br>angle_coeff 1 harmonic 63.21 110.63 # SOURCE3 507 2.7845<br>angle_coeff 2 harmonic 46.37 110.05 # SOURCE3 2092 0.6991<br>angle_coeff 3 harmonic 39.43 108.35 # SOURCE3 2380 0.9006<br>angle_coeff 4 harmonic 63.58 111.89 # CORR 700<br>angle_coeff 5 harmonic 47.20 110.86 # SOURCE3 85 1.0276<br>angle_coeff 6 harmonic 68.16 114.19 # SOURCE3 517 6.5960<br>angle_coeff 7 harmonic 62.45 120.12 # CORR 31<br>angle_coeff 8 harmonic 65.44 111.55 # CORR 884<br>angle_coeff 9 harmonic 65.44 111.55 # CORR 884<br>angle_coeff 10 harmonic 65.44 111.55 # CORR 884<br>angle_coeff 11 harmonic 65.44 111.55 # CORR 884<br>angle_coeff 12 harmonic 64.81 119.45 # SOURCE3 35 8.2040<br>angle_coeff 13 harmonic 64.81 119.45 # SOURCE3 35 8.2040<br>angle_coeff 14 harmonic 64.66 115.97 # SOURCE3 4 3.0507<br>angle_coeff 15 harmonic 68.16 114.19 # SOURCE3 517 6.5960<br>angle_coeff 16 harmonic 68.16 114.19 # SOURCE3 517 6.5960<br>angle_coeff 17 harmonic 68.16 114.19 # SOURCE3 517 6.5960<br>angle_coeff 18 harmonic 68.16 114.19 # SOURCE3 517**[[email protected]... step_000]**
THIS IS THE last line executed in the log.lammps
Can you explain to me what the problem is and how I can resolve it?
Thanks in advance,
This is not an error from LAMMPS itself is it?
Maybe you should ask the authors of your tool why and when
they flag that error?
