LAMMPS on cluster
Hi all,
To install LAMMPS on a cluster locally, I installed fftw and openmpi locally and then I installed LAMMPS, when I want to run a simulation I have the following error:
[0,1,0]: uDAPL on host compute-0-0.local was unable to find any NICs.
Another transport will be used instead, although this may result in
lower performance.
This is not a lammps error, but an error due to a misconfigured or
nonworking MPI installation. You have to fix that first.
Axel
