Dear all
I have installed LAMMPS on macBookPro using brewer as explained in the documentation.
All works good except that an error message comes when running the test “brew test lammps -v” .
The gcc libraries are installed in /usr/local/lib/gcc/6/… (this means it is gcc version 6)
While lammps is calling libraries in /usr/local/lib/gcc/5/… (version 5)
The solution is to copy …/6/ directory content to a …/5/ directory if not available.
Simply use :
cp –pR 6 5 under /usr/local/lib/gcc
and all will go fine with the test : brew test lammps -v
Nevertheless I have a question.
It seems that the installed version is 10 FEB 2016. What is the way for upgrading to the next Mac OS X stable version
Is “brew install lammps” working and will overwrite the previous installation ? or should I use something like “brew uninstall lammps” and further install new version
Thanks for your help.
Regards
Pascal
Pascal BRAULT
Direc**teur de Recherche CNRS
Délégué Scientifique Energie CNRS-INSIS
Directeur de la FR776 EPEE
GREMI UMR7344 CNRS - Université d’Orléans
14, rue d’Issoudun BP6744
F-45067 ORLEANS Cedex2
Tel. 06 31 49 87 90 - Fax. 02 38 41 71 54
http://www.univ-orleans.fr/gremi/pascal-brault
“Plasmas pave the future of fuel cells”
N’imprimez ce courriel que si cela est absolument nécessaire
