lammps on windows serial executable.
iam using windows computer. I wanted to use lammps software package. i tried to install windows serial executable.
as i run this executable programme, there is one log.lammps file created and there was another window showing Lammps(1jul 2012).
now i would like to create input files and would like to do some sample simulation.
someone help me out.
best
ravigopal allamsetty
have a look at examples directory. there are a bunch of all kinds of examples, all of those have lammps script files as well as input data files if needed.
All you need to do is just run the scripts.
http://lammps.sandia.gov/doc/Section_example.html
simulation.
you should start by helping yourself and reading the documentation.
it is included in the source package. mind you, there are always
small changes to the syntax as LAMMPS is under continuing
development so you'll have to use a version of the manual, that
matches the version of your executable.
also, you have to realize that LAMMPS is a text mode command,
so the usual way to run it would be to open a text mode command
window and then execute lammps from there and providing the name
of the input file as on the command line.
if needed.
oh yeah, and the examples are also included in the source
code package. the windows version download only includes
the executable and nothing else.
