lammps question
Hi all,
I appreciate your help.
i recently started using lammps and i am wondering if any body knows of a tutorial that can help me understand how to use the software. i read the manual and it s quite confusing, like for example am trying to run a file in vacuum, i found some discussions on-line but not quite understanding the way lammps work. thanks
sara
sara,
Hi all,
the manual mostly explains how to use individual commands. it doesn't
teach you how to do MD simulations overall. this is something that
you can better pick up from a text book. to give an example, lammps
is one tool that can be used to build a house and the documentation
tells you how to use that tool, but it doesn't tell you how to build a
house altogether, which is mostly independent from what tool exactly
you use.
lammps work. thanks
you have to be a bit more specific about where your problems are.
cheers,
