Dear users
what command can use for run lammps on cluster when terminal window
closed run continue and not stop?
for example when write " nohup " before run command for NAMD package
and Gaussian when terminal window be closed run continue
Dear users
Dear users
closed run continue and not stop?for example when write " nohup " before run command for NAMD package
you should consult with the sysadmins of your cluster how to best run
applications.
different people manage clusters differently and there are different
recommendations how to deal with it.
on the clusters, that i have a hand in managing, you would not be allowed
to run the way you describe at all, but you would have to write a shell
script and you would have to submit that script to a queuing system. you
would not be allowed to log into a compute node and it would not be
tolerated to run calculations on the login node.
but i am certain, the rules for your cluster are different and only your
local people can tell you (or point you to a webpage where those are
posted).
