For me it runs fine on just CPU. problem only shows up in run with gpu.
P.S. I am observing similar behavior while using xeon phi as well, (user-intel package, separate binary, independent from above). But there it is lot more complicated. There it only crashes when i give following 2 lines:
compute 6 upper group/group lower pair yes kspace no
compute 7 upper group/group lower pair no kspace yes
together. But it only works for large systems, I am not able to reproduce it properly. Will update if i can isolate the problem
