[lammps-users] a question about respa
Hi, ALL
I used respa in the MD simulation like this,
Hi, ALL
timestep 1.0
run_style respa 2 2 pair 1 kspace 2
How does the respa determine the inner level and the outer level ?
what "inner" and "outer" level?
you have requested two levels and
placed pair at level 1 and kspace at level 2
and since you give a factor of 2 between
level 1 and 2 you'll be doing pair (and implicitly
bond, angle, dihedral, improper) interactions
every step and kspace only every other step.
And, it doesn't apply to any minimization jobs, right ?
correct. minimization is not MD.
Hi, Alex
Thanks for your comment. I misunderstood the meaning of different levels by imagining that the whole system is divided into N parts and each part refers to one
level ( the part with the fastest motion, like O-H vibration, is the innermost, the part
with the slowest motion, is the outermost) .
In my case, the pair is evaluated every 0.5 fs and the kspace is evaluated every 1 fs.
Right ?
Regards,
Guozhen
Hi, Alex
refers to one
innermost, the part
you can have the bonded interaction handled separately as well.
the run_style command gives you the freedom (and responsibility)
to decide what to run how often.
In my case, the pair is evaluated every 0\.5 fs and the kspace is
Right ?
provided you have a 0.5fs time step, yes.
