about compute heat/flux command
1. Is compute heat/flux command only used for NVE ensemble?
2. variable J equal c_flux[1]/vol:
Is the “vol” always the total volumn of the box?
3. Is the following simulation system can use “compute myStress all stress/atom virial” for the entire box?
compute myKE all ke/atom
compute myPE all pe/atom
compute flux all heat/flux myKE myPE myStress
│ NVT │ 3 T_low=constant
│ NVE │ 2
│ NVT │ 1 T_High=constant
The ensembles for group 1, 2 and 3 are NVT, NVE and NVT respectively.
The temperature for group 1 and 3 are constant.
If you thermostat you are adding/subtracting energy, so that doesn’t make sense
with what compute heat/flux is doing.
it is in that formula - you can use whatever formula you like
I don’t understand this question. If you use group all, then
you’re computing quanties for all atoms in the box.
