hi
What is so “danger” in dangerous builds.i don’t t understand that. What is the significance of that? If my “neighbor list build” is same as the "dangerous builds " what is actually happening in simulation?
hi
What is so "danger" in dangerous builds.i don't t understand that. What is
the significance of that? If my "neighbor list build" is same as the
a dangerous build means that at least one of your atoms has
moved more than expected since the last calculation of the
neighbor lists. that means that you are in danger of your
neighbor lists being wrong. if you have dangerous builds, you
should consider doing neighbor list calculations more often
or use a larger "skin" or use a shorter time step.
it is all explained in the documentation.
cheers,
