[lammps-users] About the new "compute heat/flux"
I met some problems when using compute heat/flux in LAMMPS, version 30 Mar 2010.
First, when I run the example in its webpage, I found a mismatch of compute ID of ke and pe:
compute myKE all pe/atom
compute myPE all ke/atom
This will lead an error in the simulation.
Second, for this example, the integral I got was ~7e-11, same order but not exactly same value with what the authors provided.
I just used the input commands they showed at the bottom of the page. I wonder if there is anything wrong.
Also, for the “lamda”, it should be the thermal conductivity which the authors used kappa in the equations, right? Could the authors provide the number they used for “thermo” output frequency and timestep? For the current information, I can’t reproduce the result they got finally.
Thank you!
Jianxin Lu
jianxin@…623…
Graduate
Mechanical Eng. & Material Sci. Department, MS 321
Rice University
6100 Main Street, Houston
TX 77005
I'll let the people who authored the example included in the doc
page respond to your later Qs. For your 1st Q, the typo with KE <->
has already been fixed.
page respond to your later Qs. For your 1st Q, the typo with KE <-> PE
