I have a new potential defined as a fortran subroutine. Is it possible for me to add it to the existing potentials or must I have a .cpp and .h equivalent?
If its possible, how do I go about it?
Thank you.
Thank you.
Yes, you can add it to LAMMPS. MEAM potential included with LAMMPS is in
form of fortran files. There, pair_meam.cpp calls the fortran
subroutines. You may do something similar.
Rohit
in form of fortran files. There, pair_meam.cpp calls the fortran
which means, that the .cpp and .h are still
required to act as a proxy class.
unless you know well how to call fortran from c++
and how to pass the data around, it may be less of
a hassle to take a similar enough existing pair
style class, copy and rename it, and then translate
your fortran code into c++.
it is not *that* much different: you have free format,
have to add an ';' at the end of each line,
arrays have [] instead of () and array and loop counting
starts at 0 instead of 1. those few things cover the
majority of changes. the rest need you to have a c++
reference available or somebody who knows how to write it.
cheers,
