Hi steve,
I have retried the simulation using the 12 jan version of LAMMPS. Results are still the same. Appreciate if you have any ideas.
Huck Beng
Hi steve,
Huck Beng
I would run this NVE (no thermostatting) and see what happens.
If the Temp blows up then something is not right with your
initial geometry.
The attached script and data file for a small diamond lattice
problem run fine.
in.diamond (284 Bytes)
data.diamond (9.57 KB)
