I will soon be wanting to generate velocity autocorrelation functions (vacf) from lammps dump files. Has anyone else has done this or knows of some other software to do it?
I think fix_msd would be a great place to start adding vacf functionality in lammps. The velocity binning for a vacf is similar to the displacement binning in msd.
The next step is to Fourier transform the vacf and generate a frequency spectrum. Can fft3d be used for that?
Jeff
Jeff,
You can use CHARMM to calculate velocity autocorrelation functions if
you convert the LAMMPS velocity dump into a binary file using the script
found in the LAMMPS directory /tools/ch2lmp/other called mkdcd.f.
Here is a link to the CHARMM forum that has a small script on how to
calculate the vacf:
http://165.112.184.13/ubbthreads/showflat.php?Cat=0&Number=4602&an=0&page=1
I don't know how to do the frequency spectrum though.
Hope this helps.
Christina
([email protected]...)
