Dear all
I run a standard MD simulation using the NVT integrator, applying usual CHARMM force fields. My system consists of an amino acid dissolved in TIP3P water confined between a carbon slit pore represented by 9/3 LJ walls. The total energy of the system is kept constant (apart from usual fluctuations) by the NVT integrator up to 40 million time steps, then something strange happens: the energy suddenly starts to go down, in the same time the temperature fluctuations are remarkably reduced. I started the simulation now for the second time and the behavior is always the same. Has anybody an idea what happens there? I attached plots of the total temperature and energy.
Thank you for your help
Sabine
energy.pdf (29.4 KB)
temp.pdf (61.4 KB)
Dear all
dear sabine,
have you looked at what actually happens to the structure of your
system? what you describe sounds a lot like you have a phase transition
happening, e.g. freezing water or something similar.
cheers,
Axel's suggestion is a good one - viz your system.
It could be the classic flying icecube - your system has
frozen and is drifting with a mean velocity. You could
also monitor the center-of-mass drift with fix com.
