I'm running simulations which consist of the following steps:
1) heating my system using the temp/berendsen fix and NVE fix
2) the equilibrate it using the NVT fix
3) and subsequently equilibrate the system using the NVE fix.
When I perform the steps above in one single run everything works out fine, but when I restart the simulation from a restart file written after step 1 the result is totally different.
What can I do to prevent that behavior ?
Thanks in advance for any help.
please explain what you mean with a "totally different" result.
what is different and how? ... also if you think there is a
bug, please provide a way to reproduce it. your description
is far too general. i don't see any problems with restarting
in my simulations, for example, and i am very certain that
others would have noticed, too, if something as fundamental
would be broken.
you first have to convince us that there is something wrong.
in my simulations, for example, and i am very certain that others would have noticed, too, if something as fundamental
would be broken.
I'm simulating thiols on a gold surface. When running it in a single run my system is well ordered (herringbone) but when restarting it from a restart file the system happens to be disordered.
> would be broken.
so please provide a set of input files that reproduce this.
if you don't make it easy to track down your problem, nobody
will do it for you.
the fact that you see a difference is no ultimate proof that
there is a bug. it could just as well mean, that you are
making a mistake in your lammps scripts. please also keep in
mind that the writing to restart files is scattered throughout
many of the classes of lammps, so there can be a problem
everywhere, but also, if your restart contains data that
the read_restart is not expecting, it can corrupt your restart.
Check the thermo output before and after restarts
and compare it to continuous runs that didn't restart.
If there are tiny differences that diverge slowly
over time, then that is normal and should lead to
nothing worse that 2 simulations that are the
same in a statistical sense. If they are rapidly
radically different then there may be something
wrong with how you are restarting.
it looks as if there is either some non-initialized memory
or memory corruption going on. i have not been able to track
this down, but i get very different initial energies depending
on whether i run in serial or parallel and on what platform
i am running on. this needs some systematic testing...
I looked at your input files today. The 2 input scripts
are 350 and 100 lines long and run for 100s of 1000s
of timesteps. If you want me to debug something you'll
need to simplify it considerably. I need the smallest
script and smallest data file that will reproduce the
problem.
The current version of LAMMPS won't even read your
data file, so I suggest you upgrade to that version first.
Also, I notice that your 2nd script which reads the
restart file, also resets some velocities to 0 before doing a run.
The first input script does not do this after writing
the restart file. So why would you expect the restarted
run to give the same dynamics? Are those velocities
guaranteed to already be 0 ?
Hello, Lukas.
Sorry I can't help here, but i have a little doubt about your input.
You read initial atom coordinates, is there any need to use lattice
command again? I also read_data, but I didn't lattice it, hope my
results aren't wrong.
Hope you can solve your problem.
weina
That is what you effectively had in the original run (pair coeffs run from
the data file). In that case, LAMMPS will perform mixing to generate
I,J coeffs.
In the 1 * case, you are setting the 1,2 value (and 1,3 and 1,4 etc) to be the
same as 1,1. Which is not the same as mixing.
Hence your vdwl thermo output was totally different.
I also found a bug with hybrid neighbor lists for the (somewhat odd) case
your are modeling with a hybrid pair style
where 1,1 and 2,2 interactions are with one potential,
but 1,2 is with another. I'll post a patch for that. But it wasn't the
reason for your problem.
