I think there is a bug in fix_line_force.cpp. According to the manual webpage (http://lammps.sandia.gov/doc/fix_lineforce.html), an example of using fix lineforce command is as following:
fix hold boundary lineforce 0.0 1.0 1.0
Here the direction vector (0.0, 1.0, 1.0) is not normalized. If we give (0.0, 2.0, 2.0), I think it should work as the same as (0.0, 1.0, 1.0) because only the direction matters.
However, the code (fix_line_force.cpp) doesn’t normalize the direction vector after reading it or before applying it to force caculation:
FixLineForce::FixLineForce(LAMMPS *lmp, int narg, char **arg) :
Fix(lmp, narg, arg)
if (narg != 6) error->all(“Illegal fix lineforce command”);
xdir = atof(arg[3]);
ydir = atof(arg[4]);
zdir = atof(arg[5]);
void FixLineForce::post_force(int vflag)
double **f = atom->f;
int *mask = atom->mask;
int nlocal = atom->nlocal;
double dot;
for (int i = 0; i < nlocal; i++)
if (mask[i] & groupbit) {
dot = f[i][0]*xdir + f[i][1]*ydir + f[i][2]*zdir;
f[i][0] = dot * xdir;
f[i][1] = dot * ydir;
f[i][2] = dot * zdir;
So vectors (0.0, 1.0, 1.0) and (0.0, 2.0, 2.0) would generate forces with different magnitudes. I think this is wrong.
The same problem exists in fix_plane_force.cpp.
Please check the attached patch file which I think can fix the bug.
Xibing He
Univ. of Pennsylvania
patch_fix_line_plane.txt (1.35 KB)
