Hi Again
I have been trying to build LAMMPS using the Solaris makefile (and serial makefile) I obtained yetserday. The build runs succesfully until a point where it lists this error message.
pair_lj_charmm_coul_long.cpp: In member function virtual void PairLJCharmmCoulLong::compute(int, int)': pair_lj_charmm_coul_long.cpp:137: error:
sqrtf’ undeclared (first use this function)
pair_lj_charmm_coul_long.cpp:137: error: (Each undeclared identifier is reported only once for each function it appears in.)
pair_lj_charmm_coul_long.cpp: In member function virtual void PairLJCharmmCoulLong::compute_outer(int, int)': pair_lj_charmm_coul_long.cpp:483: error:
pair_lj_charmm_coul_long.cpp: In member function void PairLJCharmmCoulLong::init_tables()': pair_lj_charmm_coul_long.cpp:868: error:
make[1]: *** [pair_lj_charmm_coul_long.o] Error 1
make[1]: Leaving directory `/homedir/ucs404/LAMMPS/lammps-15Dec06/src/Obj_serial’
make: *** [serial] Error 2
I assume that somewhere ‘sqrtf’ should have been previously declared.
What am I doing wrong?
Can anyone help?
Rick
