[lammps-users] Building lammps
Dear lammps users,
I have successfully installed lammps in several machines.However,when I tried to build it on another one, I got this errors.Is it possible on some ones part to kindly assist me? What is the meaning of not finding lifcore?
/usr/bin/ld: cannot find -lifcore
collect2: ld returned 1 exit status
make[1]: *** […/lmp_serial] Error 1
make[1]: Leaving directory `/home/tunvir/Desktop/lammps-
24Sep09/src/Obj_serial’
make: *** [serial] Error 2
Regards,
Hanif.
Comment out the line in your Makefile.foo that sets -lifcore. As the
comment there says, it’s only needed if you are linking with Fortran
libs, and you probably aren’t. And you don’t have the ICC compiler
on your box apparently
