I have some questions about the calculations of PMF using ‘fix smd’. I used the following command in the input file after equilibration to calculate PMF.
fix pmf na smd cvel 20.0 0.0001 tether 0 0 10 0
variable dt equal 0.5
variable step equal 5000000
variable tt equal dt*step
variable distance equal 10
variable dr equal f_pmf[6]
fix out all print 1000 “{tt} {dr}” file umbrella_${distance}.pmf screen no
thermo_style custom step f_pmf[1] f_pmf[2] f_pmf[3] f_pmf[4] f_pmf[5] f_pmf[6] f_pmf[7]
run 5000000
Based on the manual, 'This fix computes a vector list of 7 quantities, the x-, y-, and z-component of the pulling force, the total force in direction of the pull, the equilibrium distance of the spring, the distance between the two reference points, and finally the accumulated PMF.
The values for the total force in direction of the pull seem to be incorrect since it decreases during all steps and not in agreement with the predicted PMF plots. Do you have any ideas where I made a mistake?
5000000 0 0 0 0 62.260006 62.259956 0
5001000 0.96437519 0.26431287 -0.010918119 -1 62.310006 62.259956 0.025025
5002000 1.9287504 0.52862575 -0.021836238 -2 62.360006 62.259956 0.10005
5003000 2.8931256 0.79293862 -0.032754357 -3 62.410006 62.259956 0.225075
5004000 3.8575007 1.0572515 -0.043672476 -4 62.460006 62.259956 0.4001
5005000 4.8218759 1.3215644 -0.054590595 -5 62.510006 62.259956 0.625125
5006000 5.7862511 1.5858772 -0.065508714 -6 62.560006 62.259956 0.90015
5007000 6.7506263 1.8501901 -0.076426833 -7 62.610006 62.259956 1.225175
5008000 7.7150015 2.114503 -0.087344951 -8 62.660006 62.259956 1.6002
5009000 8.6793767 2.3788159 -0.09826307 -9 62.710006 62.259956 2.025225
5010000 9.6437519 2.6431287 -0.10918119 -10 62.760006 62.259956 2.50025
5011000 10.608127 2.9074416 -0.12009931 -11 62.810006 62.259956 3.025275
5012000 11.572502 3.1717545 -0.13101743 -12 62.860006 62.259956 3.6003
5013000 12.536877 3.4360674 -0.14193555 -13 62.910006 62.259956 4.225325
5014000 13.501253 3.7003802 -0.15285367 -14 62.960006 62.259956 4.90035
5015000 14.465628 3.9646931 -0.16377178 -15 63.010006 62.259956 5.625375
5016000 15.430003 4.229006 -0.1746899 -16 63.060006 62.259956 6.4004
5017000 16.394378 4.4933188 -0.18560802 -17
