I wonder if the “fix thermal/conductivity” can be used in the restart file to continue the heat flux calculation from where it left off. I have noticed that No information about this fix is written to binary restart files, which has been mentioned in LAMMPS Documentation. But if I write a fix thermal/conductivity with the same ID in the restart file, the output value of the heat flux calculation by the command of fix thermal/conductivity will start from zero , not continue from the value where it left off.
How can I do?
Thanks!
KAVIANY
I have noticed that No information about this fix is written to binary restart files, which has been mentioned in LAMMPS >Documentation.
But if I write a fix thermal/conductivity with the same ID in the restart file, the output value of the heat flux calculation by >the command of fix thermal/conductivity will start from zero , not continue from the value where it left off.
These 2 statements are consistent. To do what you ask, code would have to be
added to the fix to save that quantity across restarts. You can always just
add the 2 numbers from 2 successive runs yourself.
