Hello, dear users!
I got a problem compiling lammps.
Here is Makefile:
Thank you for your attention.
linux = RedHat Linux box, Intel icc, MPICH2, FFTW
SHELL = /bin/sh
compiler/linker settings
specify flags and libraries needed for your compiler
CC = mpiCC
CCFLAGS = -O2
DEPFLAGS = -M
LINK = mpiCC
LINKFLAGS = -O2
LIB = -lstdc++ -L/home/tmog/lammps-15Dec10/lib/meam
ARCHIVE = ar
ARFLAGS = -rc
SIZE = size
LAMMPS-specific settings
specify settings for LAMMPS features you will use
LAMMPS ifdef options, see doc/Section_start.html
LMP_INC = -DLAMMPS_GZIP
MPI library, can be src/STUBS dummy lib
INC = path for mpi.h, MPI compiler settings
PATH = path for MPI library
LIB = name of MPI library
MPI_INC = -L/opt/hpmpi/include
MPI_PATH = -L/opt/hpmpi/lib
MPI_LIB = -lmpich -lpthread
FFT library, can be -DFFT_NONE if not using PPPM from KSPACE package
INC = -DFFT_FFTW, -DFFT_INTEL, -DFFT_NONE, etc, FFT compiler settings
PATH = path for FFT library
LIB = name of FFT library
FFT_INC = -DFFT_FFTW -I/home/tmog/fftw/include
FFT_PATH = -L/home/tmog/fftw/lib
FFT_LIB = -lfftw
additional system libraries needed by LAMMPS package libraries
these settings are IGNORED if the corresponding LAMMPS package
(e.g. gpu, meam) is NOT included in the LAMMPS build
SYSLIB = names of libraries
SYSPATH = paths of libraries
gpu_SYSLIB =
meam_SYSLIB = -lifcore -lsvml -lompstub -limf
reax_SYSLIB = -lifcore -lsvml -lompstub -limf
user-atc_SYSLIB = -lblas -llapack
gpu_SYSPATH =
meam_SYSPATH = -L/opt/intel/fc/10.1.015/lib
reax_SYSPATH = -L/opt/intel/fc/10.1.015/lib
user-atc_SYSPATH =
build rules and dependencies
no need to edit this section
include Makefile.package
EXTRA_INC = (LMP_INC) (PKG_INC) (MPI_INC) (FFT_INC)
EXTRA_PATH = (PKG_PATH) (MPI_PATH) (FFT_PATH) (PKG_SYSPATH)
EXTRA_LIB = (PKG_LIB) (MPI_LIB) (FFT_LIB) (PKG_SYSLIB)
Link target
(EXE): (OBJ)
(LINK) (LINKFLAGS) (EXTRA_PATH) (OBJ) (EXTRA_LIB) (LIB) -o (EXE)
(SIZE) $(EXE)
Library target
lib: (OBJ) (ARCHIVE) (ARFLAGS) (EXE) $(OBJ)
Compilation rules
.o:.cpp
(CC) (CCFLAGS) (EXTRA_INC) -c <
.d:.cpp
(CC) (CCFLAGS) (EXTRA_INC) (DEPFLAGS) < > @
Individual dependencies
DEPENDS = (OBJ:.o=.d) include (DEPENDS)
Here is error log:
mpirun Makefile.linux
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 3: SHELL: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 9: CC: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 10: CCFLAGS: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 11: DEPFLAGS: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 12: LINK: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 13: LINKFLAGS: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 14: LIB: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 15: ARCHIVE: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 16: ARFLAGS: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 17: SIZE: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 25: LMP_INC: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 32: MPI_INC: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 33: MPI_PATH: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 34: MPI_LIB: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 41: FFT_INC: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 42: FFT_PATH: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 43: FFT_LIB: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 51: gpu_SYSLIB: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 52: meam_SYSLIB: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 53: reax_SYSLIB: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 54: user-atc_SYSLIB: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 56: gpu_SYSPATH: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 57: meam_SYSPATH: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 58: reax_SYSPATH: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 59: user-atc_SYSPATH: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 65: include: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 67: LMP_INC: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 67: PKG_INC: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 67: MPI_INC: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 67: FFT_INC: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 67: EXTRA_INC: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 68: PKG_PATH: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 68: MPI_PATH: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 68: FFT_PATH: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 68: PKG_SYSPATH: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 68: EXTRA_PATH: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 69: PKG_LIB: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 69: MPI_LIB: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 69: FFT_LIB: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 69: PKG_SYSLIB: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 69: EXTRA_LIB: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 73: EXE: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 73: OBJ: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 74: LINK: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 74: LINKFLAGS: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 74: EXTRA_PATH: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 74: OBJ: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 74: EXTRA_LIB: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 74: LIB: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 74: EXE: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 74: -o: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 75: SIZE: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 75: EXE: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 79: OBJ: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 79: lib:: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 80: ARCHIVE: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 80: ARFLAGS: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 80: EXE: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 80: OBJ: command not found
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 84: fg: no job control
/home/tmog/lammps-15Dec10/src/Makefile.linux: line 85: syntax error near unexpected token newline' /home/tmog/lammps-15Dec10/src/Makefile.linux: line 85:
(CC) (CCFLAGS) (EXTRA_INC) -c <’
