Self diffusion coefficient can be computed through LAMMPS through msd command.Is there any way to compute transport diffusion coefficient (through Fick's Law) with LAMMS directly or i will have to write a post processing tool?
Regards
Regards
the latter. but do you have any reference indicating that you can get
well converged results on for MD simulation typical length and time scales?
I do not have, but i have not seen anyone who has used this in MD simulations to mention something about typical length and time scales. So i am guessing that i will try to have converge results by trying-simulations to see what's happening. What is your opinion?
why do you need my opinion, if you have already reliable sources^1 telling
you that i must be wrong. i am just saying that there is a fundamental
difference between computing an equilibrium and a non-equilibrium property
and that expect it to be non-trivial to maintain a consistent concentration
gradient for a while so you can collect the necessary raw data for computing D.
how did you expect this to work? just adding a fix to your input?
