[lammps-users] Compute force thru stress tensor
Hi,LAMMPS doesn't output force on a certain atom directly. So I wanna
compute it from the per-atom stress tensor, but the definition of
stress tensor is somewhat different from that in the continuum elastic
theory. What's the method to calculate force from the per-atom stress
tensor?
Best.
2010/11/30 Alfred Zhao <[email protected]...>:
you _can_ output the force on each atom, e.g. using a custom dump
with the fx fy fz flags.
Axel's comment is correct, if you want the total
force on each atom. If you want particle force
due to some other atoms, then look at the compute
group/group command, which you can also generate
output from.
