I decided to try the <msi2lmp tool> first. I used it and got the errors below: (My configuration set-up has Cu and C atoms).
It read the atoms' configurations successfully, but have problems with the force field.
(Is there no way to bypass the force field and just convert the atoms' configurations?)
Thanks.
Jide
Command:
msi2lmp exe 'filename' -print 3 -frc cvff.frc
Number of bonds, types = 0 0
Number of angles, types = 0 0
Number of dihedrals, types = 0 1768320623
Number of out-of-planes, types = 0 0
Reading forcefield file
Using higher version of parameters for #atom_types lp version 1.10
Using higher version of parameters for #atom_types ci version 2.00
Using higher version of parameters for #atom_types Na version 2.10
Item #atom_types has 130 entries
Item #equivalence has 129 entries
Item #nonbond has 45 entries
Item #quadratic_bond has 144 entries
Item #quadratic_angle has 234 entries
Item #torsion_1 has 82 entries
Item #out_of_plane has 36 entries
Get parameters for this molecular system
Try Atom Equivalences if needed
Unable to find mass for CU
Unable to find equivalent type for CU
Unable to find vdw data for CU
Segmentation fault
