I have a question,
when i simulate Couette's flow, i can see how atoms of flow interact with atoms of wall, but there are no interaction between atoms of wall, they're static and don't move.
What should i do to correct in my code if i want to simulate as interaction between flow and wall as interaction between atoms of walls.
Thanks a lot, Sergey R.
# 2-d LJ flow simulation
units lj
dimension 2
atom_style atomic
neighbor 0.3 bin
neigh_modify delay 5
# create geometry
lattice hex 0.7
region box block 0 20 0 10 -0.25 0.25
create_box 2 box
create_atoms 1 box
mass 1 1.0
mass 2 1.0
# LJ potentials
pair_style lj/cut 1.12246
pair_coeff * * 1.0 1.0 1.12246
# define groups
region 1 block INF INF INF 1.25 INF INF
group lower region 1
group flow subtract all lower
set group lower type 2
# initial velocities
compute mobile flow temp
velocity flow create 1.0 482748 temp mobile
fix 1 all nve
fix 2 flow temp/rescale 200 1.0 1.0 0.02 1.0
fix_modify 2 temp mobile
# Couette flow
velocity lower set 0.0 0.0 0.0
fix 3 lower setforce 0.0 0.0 0.0
fix 4 flow addforce 0.3 0.0 0.0
fix 5 flow ave/spatial 10 100 1000 y 0.0 0.5 vx y ave running file vel.profile
fix 6 all enforce2d
# Run
timestep 0.003
thermo 100
thermo_modify temp mobile
dump 1 all atom 25 dump.flow.lammpstrj
run 10000
I'm not quite sure what the question is. But the way you use the setforce command will keep these atoms from moving due to interactions with any other atoms.
Matt
Quoting "Romashevsky S." <[email protected]...>:
Don't set the force on the wall atoms to zero if you want them to respond
to interactions with the flow or each other.
03.05.2010 19:27, Matt K. Petersen пишет:
Matt
I have a question,
units lj
dimension 2
atom_style atomic
neighbor 0.3 bin
# create geometry
lattice hex 0.7
create_box 2 box
create_atoms 1 box
mass 1 1.0
mass 2 1.0
# LJ potentials
# define groups
fix 1 all nve
# Couette flow
vel.profile
fix 6 all enforce2d
# Run
timestep 0.003
thermo 100
run 10000
_______________________________________________
lammps-users mailing list
[email protected]
https://lists.sourceforge.net/lists/listinfo/lammps-users
________________________________________________
Dr. Matt K. Petersen,
Center for Biophysical Modeling and Simulation
and Department of Chemistry,
University of Utah
ok, i just want that atoms of wall interact with each other like atoms of flow do.
