Dear Users,
I need to apply classic Coulomb dry friction conditions on a group of atoms. As the simplest example consider 3 particles along x axis connected by 2 springs (bond_style harmonic). The left one is fixed by setforce 0, The right one is moved by move linear. the middle one is going to stand dry friction so that it rests until the total acting force on it reaches Fsc (maximum static friction), and afterward a constant kinetic friction Fdy is applied against its motion. Here is my input:
atom_style molecular
read_data data.txt #as follows:
{3 atoms
2 bonds
1 atom types
1 bond types
-5 100 xlo xhi
-5 5 ylo yhi
-5 5 zlo zhi
Masses
1 1
Atoms
1 1 1 0 0 0
2 1 1 1 0 0
3 1 1 2 0 0
Bonds
1 1 1 2
2 1 2 3} # end of data file
group left id 1
group midd id 2
group right id 3
bond_style harmonic/shift/cut
bond_coeff 1 5 1 10
velocity all create 0 4928459 mom yes rot yes dist uniform
timestep 0.001
thermo 100
variable Fsc equal 0.003
variable Fdy equal 0.002
#fix 1 all nve
fix 1 all nvt temp 0.01 0.01 0.001
fix 2 left setforce 0 0 0
fix 3 right move linear 0.1 0 0 units box
dump 1 all custom 1 dump.xyz id x fx
label loop
variable a loop 50000
variable FX2 equal abs(fx[2])
if “v_FX2 < 0.003” then “fix 4 midd setforce 0 NULL NULL” else “unfix 4” “fix 4 midd addforce -0.002 0 0”
run 1 pre no post no
next a
unfix 4
jump SELF loop
I expected when the spring (bond) 2 is stretched enough, the force fx[2] be bigger than Fsc and it starts to move but it doesn’t. Wrongly, with this code fx[2] always sets to 0. To overcome, I tried another way: define a friction force, FR, which is opposite of fx in static mode and equals to kinetic friction after sliding with this code:
label loop
variable a loop 10000
variable FX equal fx[2]
variable FXA equal abs(FX)
if “v_FXA < 0.003” then “variable FR equal -v_FX” else “variable FR equal -0.002”
fix 4 midd addforce v_FR 0 0
next a
unfix 4
jump SELF loop
but it doesn’t work either.
Thank you, Kamal
