Thanks Steve.
I’ve tried two things:
1. As you told me, I increase the precision and found that the dilation factor is different in xyz even if it appears at 10^-7. That for the z-axis is smaller. The ratio of Lx:Ly:Lz changes from 0.386 to 0.391.
As follows:
0 2.0232614 2.9235608 5.5379974 62108.72 -5.5149004 3.0347186 28.839654 28.839654 74.674529 5.6099543 5.7951015 5.2089364 -0.057484868 0.14193013 -0.017237353
BOX DILATE: 0 1.0000010618 28.8397
BOX DILATE: 1 1.0000010618 28.8397
BOX DILATE: 2 1.00000085774 74.6745
BOX DILATE: 2 1.00000085774 74.6746
15620 2.651821 3.8031009 2.6409022 93210.505 -1.9305568 3.977504 33.089003 33.089003 85.132912 2.6616096 2.6479815 2.6131157 -0.012724146 0.070555751 -0.061006088
BOX DILATE: 0 1.0000037263 33.089
BOX DILATE: 1 1.0000037263 33.089
BOX DILATE: 2 1.00000352223 85.1329
BOX DILATE: 0 1.0000037263 33.0891
BOX DILATE: 1 1.0000037263 33.0891
BOX DILATE: 2 1.00000352223 85.1332
29999 2.6016707 3.7902786 3.302639 86438.794 -2.0548799 3.9022829 32.330657 32.330657 82.695075 3.3702441 3.3133025 3.2243705 -0.0099711106 0.030020318 -0.028955017
BOX DILATE: 0 0.999995338825 32.3307
BOX DILATE: 1 0.999995338825 32.3307
BOX DILATE: 2 0.999995134759 82.6951
BOX DILATE: 0 0.999995338825 32.3305
BOX DILATE: 1 0.999995338825 32.3305
BOX DILATE: 2 0.999995134759 82.6947
2. The para-pure Gay-Berne bulk system has been run with the same p-style xyz which was built by delete all the LJ walls in the initial structure. It is a big surprise that the ratio of Lx:Ly:Lz changes from 0.3862 0.3862 1.0000 to 0.3910 0.3910 1.0000 after 30000 step npt xyz runnings. But the ratio keeps well as a constant for the pure GB bulk after the same simulation.
So maybe the error is caused by the precision. It just happens in some case.
