Hi all. I found out that the result of thermal conductivity computing depends on the number of processors. I’ve used the example script for solid Ar from page http://lammps.sandia.gov/doc/compute_heat_flux.html
conductivity computing depends on the number of processors. I've used the
Results of computing:
num_process therm_conductivity [W/mK]
1 0.2894747897
2 0.3226395484
3 0.3266229955
4 0.3114426029
LAMMPS 13 Sep 2010
OS Ubuntu 10.04
How can I avoid this problem?
are you sure there actually _is_ a problem?
have you checked how well each of the
values are converged?
different number of processors will
result in different but equivalent
trajectories due to limitations of floating
point math.
The velocity command in that script will generate
velocites that differ (for a particular atom) depending
on the number of procs. See the loop option on the
velocity command, if you want to avoid that. Thus
running on different P will give you different trajectories
and results, but statistically similar. As Axel said, for
a small system, with a short runs, the variations you
are seeing seems normal.
