Dear,
I want to know the difference of codes for the same system as follows,
group wall type 1
group mobile type 2
code 1:
fix 1 mobile nvt 1.0 1.0 1.0 drag 0.2
the fix does not include group wall, so does not change the velocity of the wall
code 2:
fix 1 all nvt 1.0 1.0 1.0 drag 0.2
fix 2 wall setforce 0.0 0.0 0.0 use setforce command to not change the velocity of the wall
I have test the two codes in the same script, but code 2 give a physical result, code 1 give a wrong result .
I am confused? Any suggestion, Thanks
