?try setting restartinfo = 0; in the pair style quip constructor, compile,
and try reading the restart again. ?
I agree that it’s a bug in pair_quip, and unfortunately this doesn’t fix it. It appears that some
sort of flag is set in the restart file, so it tries to call read_restart and gets the Pair method.
Would it not be better if the failure happened during write_restart,
rather than at the read_restart time which might happen after weeks of
running??a test could be added, but if somebody uses write_restart after weeks of
running?, the effect would be about the same (if not worse).
Yeah, I agree that this isn’t really a good solution.
if you start arguing like that, you are opening pandora’s box. ?that kind
of logic could be? applies to a gazillion settings in LAMMPS. i would love
to see this happen, but actually with even more rigid requirements, e.g. by
having to pass some bitmasked enums to the constructor and making those
immutable settings. also there are a bunch of other settings, that would
benefit enormously from being only changeable through getter/setter
methods. what LAMMPS does in that regard is conceptually not very different
from using common blocks. unfortunately, it is an uphill battle, since
steve has a kind and generous mind and assumes that everybody is a smart
programmer and tests and double checks everything properly, while i have a
dirty mind and i don’t trust anybody to “do the right thing™”.
it actually took some effort and a couple of rewrites to get restart
checking stuff into LAMMPS in a way that is compatible with steve’s code
design preferences. as the LOTL he has the final word…
This new test has already opened the Pandora’s box - it is a consistency check. And
moreover it triggers existing (or, arguably, creates new) bugs in existing pair styles.
And even worse, it does so in a way that leads to unreadable restart files. From what I can
tell, the restart file itself has some flag set (NO_PAIR?) which causes the read restart code to
call the potentials’ read_restart method. Setting restartinfo=0 doesn’t seem to change that, because
the flag is already in the restart file. The only way I found to successfully restart is to add a nop
PairQUIP::read_restart. And now these restart files will be forever incompatible with the properly
fixed version of the pair_style, which would presumably have restartinfo=0 and no read_restart
method.
It’s not a that big a deal, but it’d be nice if someone could check all the pair styles and (probably
just using grep) confirm that any that don’t set restartinfo=0 actually have read_restart
and write_restart methods defined. I’d be happy to do that check myself if that’s helpful,
but I’m not sure where to look for all the pair_*.cpp source files (given that some are in
optional packages).
Noam
