[lammps-users] dihedral check issue on epoxy group
Dear LAMMPS users
I built up a molecular system with epoxy groups, but the epoxy groups can not pass the dihedral check in LAMMPS. The error message is as follows.
ERROR on proc 17: Invalid atom ID in Dihedrals section of data file (…/atom.cpp:1167)
Last command: read_data gr_epoxy_channel_lmp.data
I believe the problem is here, and below is the one line of dihedral list in the data file.
8650 8 1313 1282 1295 1313
I think the LAMMPS program regarding the dihedral is invalid because the 1 and 4 atoms have the same ID.
However, the dihedral in the epoxy group really has the same oxygen atom on position 1 and 4.
Is there any way to skip this problem?
BEST,
Tzu-Jen
A dihedral definition with such a shared atom makes no sense. Its dihedral angle cannot change.
Axel.
