[lammps-users] Dislocation minimization at zero degree kelvin
A week back, I have posted a problem on minimization at zero degree kelvin. I could sort out how to minimize a dislocation in a Al crystal.
My problem now is: Splitting distance between partials after minimization is very high and equal to 50 Angstroms, when I used energy tolerance to 1.0e-7.
But the elastic solution for Aluminium is around 16 Angstroms. I am able to get this distance only when I increase the tolerance to 1.e-5.
Is minimization so sensetive to energy tolerance? Am I doing any mistake in i/p. Please help. I am attaching the i/p file
# LAMMPS data file for rigid bodies
99855 atoms
1 atom types
-104 104 xlo xhi
-53 49 ylo yhi
0 73 zlo zhi
This seems wierd, because presumbly with high precision tolerance should have better results. I’m guessing maybe this has sth to do with the potential.
One comment: The splitting distance between two partials should depends on the potential you are using, including shear modulus, stacking fault energy, etc. They vary for different potentials.
AC
mistake in i/p
Don't know, but the energy landscape in general is very bumpy for
solids and defects. So it is possible to find different local minima.
