Dear Steve and everyone,
Do you have any experience about the thermal conductivity simulation of graphene sheets?
Now I’m using Muller-Plathe method to simulate the thermal conductivity of the graphene sheet with the AIREBO potential, but my result is far away from the reported and experimental results. I simulated graphene sheets with several different sizes and found all of the thermal conductivity are around ~ 200W/K/m, which is 10~20 times smaller than the published result. I used the following input file to calculate the thermal conductivity:
atom_style molecular
read_restart res_0.7ns # restart file after 0.5ns NVT simulation and 0.2ns NVE simulation at 300K
pair_style airebo 3.0 1 1
pair_coeff * * CH.airebo C
timestep 0.001
velocity all create 300 1234567 dist gaussian
fix 2 all nve #perform constant NVE integration to update position and velocity for atoms in the group each timestep
thermo 1000
fix flux all thermal/conductivity 50 z 24
compute ke all ke/atom
variable temp atom c_ke[]/0.0001292355
fix 3 all ave/spatial 10 100 1000 z lower 3.0 v_temp file tmp.profile units box
dump ani all xyz 5000 graphtraj.xyz
dump_modify ani format “C %14.6g %14.6g %14.6g”
thermo 1000
thermo_style custom step ke pe etotal temp press f_flux
run 4000000
figures.doc (240 KB)
