[lammps-users] dpd and charge atom_style
I have written a simple input script that works well.
I have used "atom_style charge". But when I change the atom style to
"hybrid charge dpd" to use heat/flux compute command, the results go to
the infinite values.
Would you please tell me how I can use both of dpd and charge atom style
correctly ?
Regards,
Ali Rajabpour
atom_style charge # => (hybrid charge dpd)
# create geometry
read_data datafile.txt
# Buck potentials
pair_style buck/coul/cut 10
#Si type 1, O type 2
pair_coeff 1 1 0.0 0.10 0.0
pair_coeff 1 2 18003.7572 0.205205 133.5381
pair_coeff 2 2 1388.7730 0.362319 175.0
#initial velocities
velocity all create 300.0 482748
fix 1 all nve
# Run
timestep 0.0005
run 10000
You should get this error if you try to use atom_style charge
with compute heat/flux:
ERROR: Compute heat/flux requires ghost atoms store velocity
so your email doesn't really make sense to me.
You can certainly use atom_style hybrid (e.g. with charge and dpd).
The format for the data file with atom_style hybrid is explained
in doc/read_data.html.
