hello.
in the lammps manual only tell:
"The xyz style writes XYZ files, which is a simple text-based coordinate format that many codes can read"
i run a simulation with dump command and xyz:
dump 1 all xyz 1000 /home/lsi/bernardo/deposicion/GAAS2/deposit.xyz
and only generated 1 xyz file with the first snapshot,
someone can tell me if i can put some more parameter in this command line for obtain 1 xyz each 1000 steps.
thank for all.
