Hi all,
what is the meaning of eflag and vflag say, for instance, in
pair_lj_cut.cpp in the src dir?
Are variables like these and the methods that use them commented
somewhere in the code?
Thank you, I have just started playing a bit with the source code.
Davide
Hi all,
hi davide!
eflag != 0 means: compute energy contributions in this step
vflag != 0 means: compute virial contributions in this step
the exact value indicates whether per atom or total contributions
are supposed to be computed.
have a look at pair.cpp and the particularly Pair::ev_setup()
and the Pair::ev_tally*() methods.
the in-file documentation is not quite as it should be.
given the way that LAMMPS is structured, it would be
a worthwhile project (particularly for somebody wanting
to learn the code) to convert the sources to doxygen
compatible sources and thus be easily to generate a
"programmers reference" from the code.
ciao,
