Dear Steve,
There is a bug in the file of fix_temp_rescale.cpp. I think it should be fix temp/rescale cannot be 0.0.
Dear Steve,
I'll change the error message to "rescale"
Re: T of a one-particle system. If you don't think
LAMMPS is adjusting the degrees-of-freedom correctly
for the one-particle case, you can adjust it yourself
with the compute_modify extra command.
