Hello
I want to install LAMMPS on linux machine .When i was doing gmake i got the following errors…
Makefile:93: delete_atoms.d: No such file or directory
Makefile:93: delete_bonds.d: No such file or directory
Makefile:93: dihedral_charmm.d: No such file or directory
Makefile:93: dihedral.d: No such file or directory
Makefile:93: dihedral_harmonic.d: No such file or directory
Makefile:93: dihedral_helix.d: No such file or directory
Makefile:93: dihedral_hybrid.d: No such file or directory
Makefile:93: dihedral_multi_harmonic.d: No such file or directory
Makefile:93: dihedral_opls.d: No such file or directory
Makefile:93: displace_atoms.d: No such file or directory
Makefile:93: displace_box.d: No such file or directory
Makefile:93: domain.d: No such file or directory
Makefile:93: dump_atom.d: No such file or directory
Makefile:93: dump_cfg.d: No such file or directory
Makefile:93: dump.d: No such file or directory
Makefile:93: dump_custom.d: No such file or directory
Makefile:93: dump_dcd.d: No such file or directory
Makefile:93: dump_local.d: No such file or directory
Makefile:93: dump_xyz.d: No such file or directory
Makefile:93: error.d: No such file or directory
Makefile:93: ewald.d: No such file or directory
Makefile:93: fft3d.d: No such file or directory
Makefile:93: fft3d_wrap.d: No such file or directory
Makefile:93: finish.d: No such file or directory
Makefile:93: fix_addforce.d: No such file or directory
Makefile:93: fix_ave_atom.d: No such file or directory
Makefile:93: fix_aveforce.d: No such file or directory
Makefile:93: fix_ave_histo.d: No such file or directory
Makefile:93: fix_ave_spatial.d: No such file or directory
Makefile:93: fix_ave_time.d: No such file or directory
Makefile:93: fix_bond_break.d: No such file or directory
Makefile:93: fix_bond_create.d: No such file or directory
Makefile:93: fix_bond_swap.d: No such file or directory
Makefile:93: fix_box_relax.d: No such file or directory
Makefile:93: fix.d: No such file or directory
Makefile:93: fix_deform.d: No such file or directory
Makefile:93: fix_deposit.d: No such file or directory
Makefile:93: fix_drag.d: No such file or directory
Makefile:93: fix_dt_reset.d: No such file or directory
Makefile:93: fix_efield.d: No such file or directory
Makefile:93: fix_enforce2d.d: No such file or directory
Makefile:93: fix_evaporate.d: No such file or directory
Makefile:93: fix_gravity.d: No such file or directory
Makefile:93: fix_heat.d: No such file or directory
Makefile:93: fix_indent.d: No such file or directory
Makefile:93: fix_langevin.d: No such file or directory
Makefile:93: fix_lineforce.d: No such file or directory
Makefile:93: fix_minimize.d: No such file or directory
Makefile:93: fix_momentum.d: No such file or directory
Makefile:93: fix_move.d: No such file or directory
Makefile:93: fix_nph.d: No such file or directory
Makefile:93: fix_npt.d: No such file or directory
Makefile:93: fix_npt_sphere.d: No such file or directory
Makefile:93: fix_nve.d: No such file or directory
Makefile:93: fix_nve_limit.d: No such file or directory
Makefile:93: fix_nve_noforce.d: No such file or directory
Makefile:93: fix_nve_sphere.d: No such file or directory
Makefile:93: fix_nvt.d: No such file or directory
Makefile:93: fix_nvt_sllod.d: No such file or directory
Makefile:93: fix_nvt_sphere.d: No such file or directory
Makefile:93: fix_orient_fcc.d: No such file or directory
Makefile:93: fix_planeforce.d: No such file or directory
Makefile:93: fix_press_berendsen.d: No such file or directory
Makefile:93: fix_print.d: No such file or directory
Makefile:93: fix_recenter.d: No such file or directory
Makefile:93: fix_respa.d: No such file or directory
Makefile:93: fix_rigid.d: No such file or directory
Makefile:93: fix_set_force.d: No such file or directory
Makefile:93: fix_shake.d: No such file or directory
Makefile:93: fix_shear_history.d: No such file or directory
Makefile:93: fix_spring.d: No such file or directory
Makefile:93: fix_spring_rg.d: No such file or directory
Makefile:93: fix_spring_self.d: No such file or directory
Makefile:93: fix_store_coord.d: No such file or directory
Makefile:93: fix_store_force.d: No such file or directory
Makefile:93: fix_temp_berendsen.d: No such file or directory
Makefile:93: fix_temp_rescale.d: No such file or directory
Makefile:93: fix_thermal_conductivity.d: No such file or directory
Makefile:93: fix_tmd.d: No such file or directory
Makefile:93: fix_ttm.d: No such file or directory
Makefile:93: fix_viscosity.d: No such file or directory
Makefile:93: fix_viscous.d: No such file or directory
Makefile:93: fix_wall.d: No such file or directory
Makefile:93: fix_wall_harmonic.d: No such file or directory
Makefile:93: fix_wall_lj126.d: No such file or directory
Makefile:93: fix_wall_lj93.d: No such file or directory
Makefile:93: fix_wall_reflect.d: No such file or directory
Makefile:93: fix_wall_region.d: No such file or directory
Makefile:93: force.d: No such file or directory
Makefile:93: group.d: No such file or directory
Makefile:93: improper.d: No such file or directory
Makefile:93: improper_cvff.d: No such file or directory
Makefile:93: improper_harmonic.d: No such file or directory
Makefile:93: improper_hybrid.d: No such file or directory
Makefile:93: input.d: No such file or directory
Makefile:93: integrate.d: No such file or directory
Makefile:93: kspace.d: No such file or directory
Makefile:93: lammps.d: No such file or directory
Makefile:93: lattice.d: No such file or directory
Makefile:93: library.d: No such file or directory
Makefile:93: main.d: No such file or directory
Makefile:93: memory.d: No such file or directory
Makefile:93: min_cg.d: No such file or directory
Makefile:93: min.d: No such file or directory
Makefile:93: min_hftn.d: No such file or directory
Makefile:93: minimize.d: No such file or directory
Makefile:93: min_linesearch.d: No such file or directory
Makefile:93: min_sd.d: No such file or directory
Makefile:93: modify.d: No such file or directory
Makefile:93: neigh_bond.d: No such file or directory
Makefile:93: neighbor.d: No such file or directory
Makefile:93: neigh_derive.d: No such file or directory
Makefile:93: neigh_full.d: No such file or directory
Makefile:93: neigh_gran.d: No such file or directory
Makefile:93: neigh_half_bin.d: No such file or directory
Makefile:93: neigh_half_multi.d: No such file or directory
Makefile:93: neigh_half_nsq.d: No such file or directory
Makefile:93: neigh_list.d: No such file or directory
Makefile:93: neigh_request.d: No such file or directory
Makefile:93: neigh_respa.d: No such file or directory
Makefile:93: neigh_stencil.d: No such file or directory
Makefile:93: output.d: No such file or directory
Makefile:93: pack.d: No such file or directory
Makefile:93: pair_airebo.d: No such file or directory
Makefile:93: pair_born_coul_long.d: No such file or directory
Makefile:93: pair_buck_coul_cut.d: No such file or directory
Makefile:93: pair_buck_coul_long.d: No such file or directory
Makefile:93: pair_buck.d: No such file or directory
Makefile:93: pair_coul_cut.d: No such file or directory
Makefile:93: pair_coul_debye.d: No such file or directory
Makefile:93: pair_coul_long.d: No such file or directory
Makefile:93: pair.d: No such file or directory
Makefile:93: pair_dpd.d: No such file or directory
Makefile:93: pair_eam_alloy.d: No such file or directory
Makefile:93: pair_eam.d: No such file or directory
Makefile:93: pair_eam_fs.d: No such file or directory
Makefile:93: pair_hybrid.d: No such file or directory
Makefile:93: pair_hybrid_overlay.d: No such file or directory
Makefile:93: pair_lj96_cut.d: No such file or directory
Makefile:93: pair_lj_charmm_coul_charmm.d: No such file or directory
Makefile:93: pair_lj_charmm_coul_charmm_implicit.d: No such file or directory
Makefile:93: pair_lj_charmm_coul_long.d: No such file or directory
Makefile:93: pair_lj_cut_coul_cut.d: No such file or directory
Makefile:93: pair_lj_cut_coul_debye.d: No such file or directory
Makefile:93: pair_lj_cut_coul_long.d: No such file or directory
Makefile:93: pair_lj_cut_coul_long_tip4p.d: No such file or directory
Makefile:93: pair_lj_cut.d: No such file or directory
Makefile:93: pair_lj_expand.d: No such file or directory
Makefile:93: pair_lj_gromacs_coul_gromacs.d: No such file or directory
Makefile:93: pair_lj_gromacs.d: No such file or directory
Makefile:93: pair_lj_smooth.d: No such file or directory
Makefile:93: pair_morse.d: No such file or directory
Makefile:93: pair_soft.d: No such file or directory
Makefile:93: pair_sw.d: No such file or directory
Makefile:93: pair_table.d: No such file or directory
Makefile:93: pair_tersoff.d: No such file or directory
Makefile:93: pair_tersoff_zbl.d: No such file or directory
Makefile:93: pair_yukawa.d: No such file or directory
Makefile:93: pppm.d: No such file or directory
Makefile:93: pppm_tip4p.d: No such file or directory
Makefile:93: random_mars.d: No such file or directory
Makefile:93: random_park.d: No such file or directory
Makefile:93: read_data.d: No such file or directory
Makefile:93: read_restart.d: No such file or directory
Makefile:93: region_block.d: No such file or directory
Makefile:93: region_cone.d: No such file or directory
Makefile:93: region.d: No such file or directory
Makefile:93: region_cylinder.d: No such file or directory
Makefile:93: region_intersect.d: No such file or directory
Makefile:93: region_plane.d: No such file or directory
Makefile:93: region_prism.d: No such file or directory
Makefile:93: region_sphere.d: No such file or directory
Makefile:93: region_union.d: No such file or directory
Makefile:93: remap.d: No such file or directory
Makefile:93: remap_wrap.d: No such file or directory
Makefile:93: replicate.d: No such file or directory
Makefile:93: respa.d: No such file or directory
Makefile:93: run.d: No such file or directory
Makefile:93: set.d: No such file or directory
Makefile:93: shell.d: No such file or directory
Makefile:93: special.d: No such file or directory
Makefile:93: temper.d: No such file or directory
Makefile:93: thermo.d: No such file or directory
Makefile:93: timer.d: No such file or directory
Makefile:93: universe.d: No such file or directory
Makefile:93: update.d: No such file or directory
Makefile:93: variable.d: No such file or directory
Makefile:93: velocity.d: No such file or directory
Makefile:93: verlet.d: No such file or directory
Makefile:93: write_restart.d: No such file or directory
icc -O -DLAMMPS_GZIP -DMPICH_IGNORE_CXX_SEEK -DFFT_FFTW -M write_restart.cpp > write_restart.d
/bin/sh: icc: command not found
make[1]: *** [write_restart.d] Error 127
make[1]: Leaving directory /horses/vasp/project/lammps-2Feb10/src/Obj_linux' make: *** [linux] Error 2 [[email protected]... src]$ gmake mac gmake[1]: Entering directory
/horses/vasp/project/lammps-2Feb10/src/Obj_mac’
Makefile:93: angle_charmm.d: No such file or directory
Makefile:93: angle_cosine.d: No such file or directory
Makefile:93: angle_cosine_delta.d: No such file or directory
Makefile:93: angle_cosine_squared.d: No such file or directory
Makefile:93: angle.d: No such file or directory
Makefile:93: angle_harmonic.d: No such file or directory
Makefile:93: angle_hybrid.d: No such file or directory
Makefile:93: angle_table.d: No such file or directory
Makefile:93: atom.d: No such file or directory
Makefile:93: atom_vec_angle.d: No such file or directory
Makefile:93: atom_vec_atomic.d: No such file or directory
Makefile:93: atom_vec_bond.d: No such file or directory
Makefile:93: atom_vec_charge.d: No such file or directory
Makefile:93: atom_vec.d: No such file or directory
Makefile:93: atom_vec_full.d: No such file or directory
Makefile:93: atom_vec_hybrid.d: No such file or directory
Makefile:93: atom_vec_molecular.d: No such file or directory
Makefile:93: bond.d: No such file or directory
Makefile:93: bond_fene.d: No such file or directory
Makefile:93: bond_fene_expand.d: No such file or directory
Makefile:93: bond_harmonic.d: No such file or directory
Makefile:93: bond_hybrid.d: No such file or directory
Makefile:93: bond_morse.d: No such file or directory
Makefile:93: bond_nonlinear.d: No such file or directory
Makefile:93: bond_quartic.d: No such file or directory
Makefile:93: bond_table.d: No such file or directory
Makefile:93: change_box.d: No such file or directory
Makefile:93: comm.d: No such file or directory
Makefile:93: compute_angle_local.d: No such file or directory
Makefile:93: compute_bond_local.d: No such file or directory
Makefile:93: compute_centro_atom.d: No such file or directory
Makefile:93: compute_cna_atom.d: No such file or directory
Makefile:93: compute_com.d: No such file or directory
Makefile:93: compute_com_molecule.d: No such file or directory
Makefile:93: compute_coord_atom.d: No such file or directory
Makefile:93: compute.d: No such file or directory
Makefile:93: compute_dihedral_local.d: No such file or directory
Makefile:93: compute_displace_atom.d: No such file or directory
Makefile:93: compute_erotate_sphere.d: No such file or directory
Makefile:93: compute_group_group.d: No such file or directory
Makefile:93: compute_gyration.d: No such file or directory
Makefile:93: compute_gyration_molecule.d: No such file or directory
Makefile:93: compute_heat_flux.d: No such file or directory
Makefile:93: compute_improper_local.d: No such file or directory
Makefile:93: compute_ke_atom.d: No such file or directory
Makefile:93: compute_ke.d: No such file or directory
Makefile:93: compute_msd.d: No such file or directory
Makefile:93: compute_msd_molecule.d: No such file or directory
Makefile:93: compute_pair_local.d: No such file or directory
Makefile:93: compute_pe_atom.d: No such file or directory
Makefile:93: compute_pe.d: No such file or directory
Makefile:93: compute_pressure.d: No such file or directory
Makefile:93: compute_property_atom.d: No such file or directory
Makefile:93: compute_property_local.d: No such file or directory
Makefile:93: compute_property_molecule.d: No such file or directory
Makefile:93: compute_rdf.d: No such file or directory
Makefile:93: compute_reduce.d: No such file or directory
Makefile:93: compute_reduce_region.d: No such file or directory
Makefile:93: compute_stress_atom.d: No such file or directory
Makefile:93: compute_temp_com.d: No such file or directory
Makefile:93: compute_temp.d: No such file or directory
Makefile:93: compute_temp_deform.d: No such file or directory
Makefile:93: compute_temp_partial.d: No such file or directory
Makefile:93: compute_temp_profile.d: No such file or directory
Makefile:93: compute_temp_ramp.d: No such file or directory
Makefile:93: compute_temp_region.d: No such file or directory
Makefile:93: compute_temp_sphere.d: No such file or directory
Makefile:93: create_atoms.d: No such file or directory
Makefile:93: create_box.d: No such file or directory
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M write_restart.cpp > write_restart.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M verlet.cpp > verlet.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M velocity.cpp > velocity.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M variable.cpp > variable.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M update.cpp > update.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M universe.cpp > universe.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M timer.cpp > timer.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M thermo.cpp > thermo.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M temper.cpp > temper.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M special.cpp > special.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M shell.cpp > shell.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M set.cpp > set.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M run.cpp > run.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M respa.cpp > respa.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M replicate.cpp > replicate.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M remap_wrap.cpp > remap_wrap.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M remap.cpp > remap.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M region_union.cpp > region_union.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M region_sphere.cpp > region_sphere.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M region_prism.cpp > region_prism.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M region_plane.cpp > region_plane.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M region_intersect.cpp > region_intersect.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M region_cylinder.cpp > region_cylinder.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M region.cpp > region.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M region_cone.cpp > region_cone.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M region_block.cpp > region_block.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M read_restart.cpp > read_restart.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M read_data.cpp > read_data.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M random_park.cpp > random_park.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M random_mars.cpp > random_mars.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M pppm_tip4p.cpp > pppm_tip4p.d
c++ -O -DLAMMPS_GZIP -I…/STUBS -DFFT_FFTW -M pppm.cpp > pppm.d
In file included from fft3d_wrap.h:18,
from pppm.cpp:32:
fft3d.h:164:18: error: fftw.h: No such file or directory
gmake[1]: *** [pppm.d] Error 1
gmake[1]: Leaving directory `/horses/vasp/project/lammps-2Feb10/src/Obj_mac’
gmake: *** [mac] Error 2
Please help me for solving that error.
Manisha.
