I am new for lammps, I just compiled the lammps under RHEL 5.4, get the executable “lmp_redhat”. I am using ./lmp_redhat > ./bench/in.lj. There is no problem, but when I try ./lmp_redhat > ./bench/in.chain. or any other in file. it keeps showing :ERROR: Invalid atom style
Could you please give me some suggestions? Thanks,
Helen
executable "lmp_redhat". I am using ./lmp_redhat > ./bench/in.lj. There is
that means that the input uses an optional component of lammps
that you didn't configure in with "make yes-<packagename>".
please re-read the compilation and installation instructions.
cheers,
Helen
Happy Helen
Sorry you are not happy, Helen. Probably you need
to build LAMMPS with a package installed that includes
the atom_style you are trying to use. E.g. if building
for machine foo:
make yes-molecule (this has atom_style bond or full)
make foo
Thanks a lot:)
I rebuilt with yes-molecule last night, it comes with lmp-rhel5 executable.
But I came across the MPI issue:
Fatal error in MPI_Init:
Other MPI error, error stack:
MPIR_Init_thread(411): Initialization failed
(unknown)(): Other MPI error
I am using openmpi, is there any special requirement for MPI?
Helen
LAMMPS should work with any MPI. This
error looks like a problem with how MPI is
setup or initialized on your system.
