[lammps-users] Error: kspace style is incompatible with pair style
Hi all,
I am simulating an ionic liquid system, and
I need to have the long range interaction calculated.
When I put the input like:
pair_style lj/cut/coul/long 10
kspace_style pppm 0.0001
I get this error Error: kspace style is incompatible with pair style
But as per the manual this combination should work fine.
Now, if I do not use long interaction like below it works fine.
pair_style lj/cut/coul/cut 15 15
#kspace_style pppm 0.0001
What may be wrong and how do I solve this problem and calculate long range interaction.
Thanks for suggestions
Mousumi
Hi all,
this works for me. please produce a full
self contained input that reproduces this
error message and let us know which
version of lammps you are using exactly.
cheers,
